brake line pressure testing?
Old Aug 16, 2017 | 01:16 AM
another-user's Avatar
another-user
Default brake line pressure testing?
ive got a 69 thats pulling the left, hard, under braking. ive got new rubber brake lines on both fronts and new calipers. neither has made a real difference yet. also have put a new MC and freshly rebuilt booster on a few years ago. pads and rotors are a couple years old too, but still like new.
the lines have been bled, stopping power is excellent, and the brakes feel excellent, with the notable exception that the car pulls hard to the left still. its better with all the new gear, but its still an issue
ive checked the suspension components (all new within the last 6-7 years) and everything is fine there.
which leaves me with pressure checking the lines them self. im hoping to see if both sides are equal, or if the drivers side is much lower than the pass side.
oops, meant to put this in tech, not general. go ahead and ignore this.
Old Aug 17, 2017 | 11:14 AM
MelWff's Avatar
MelWff
if the car is pulling hard to the left, the problem is with the passenger side. Check if the pistons are binding. You replaced the calipers but kept the old pads? You are sure you dont have a problem with the passenger side rotor, glazed?
Old Aug 18, 2017 | 10:56 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Also.........Could the steel brake line that goes to the passenger caliper be damaged/rusted internally somewhere which would restrict the fluid pressure?
Old Aug 18, 2017 | 12:37 PM
7T1vette's Avatar
7T1vette
A hard line would need to be nearly closed off to restrict pressure. The hard lines should be checked, but significant damage would need to be seen to have any concern about pressure drop (ie, crushed).
I'm leaning toward glazed pads on the right side. Are the rotors and pads on the front of the same manufacturers and vintage? Rotor material and surface finishing methods can have performance differences. When working on brakes, components need to be the SAME on opposite sides of front or rear wheels.
Old Aug 18, 2017 | 05:53 PM
terry82's Avatar
terry82
Take pads from one side and trade with the other side ,drive and see what happens. there is a gauge that will test brake line pressure.https://www.otctools.com/products/br...ssure-test-kit there are cheaper ones.
Old Jul 9, 2020 | 07:11 PM
derekderek's Avatar
derekderek
bleed the right again. and again. and again...
Old Jul 9, 2020 | 07:31 PM
Gold Dragon's Avatar
Gold Dragon
This...I was thinking something similar. Had a Malibu that sat for a while. When it was road worthy again it would pull hard to one side. Turned out the steel line from front to back corroded. Only the fronts would work, and the dominant side would win. Could still get fluid out when bleeding...just not enough to push the rear brakes. Once the steel line was replaced. Take the car out to a safe spot and jamb the brakes hard. See which wheels lock and which ones don't.
Old Jul 9, 2020 | 07:37 PM
interpon's Avatar
interpon
bleed For 3 years
Old Jul 9, 2020 | 07:49 PM
HeadsU.P.'s Avatar
HeadsU.P.
Its bad enough we have to watch old **** on TV.
Lately we have to watch old **** on the forum.
STOP IT !!!!!
Old Jul 10, 2020 | 12:55 AM
doorgunner's Avatar
doorgunner
Originally Posted by interpon
bleed For 3 years
Bitten by the "Related Thread" monster!
To brake line pressure testing?
