C3 Engine Removal
Old Aug 16, 2017 | 10:37 AM
don1947's Avatar
don1947
8th Gear
Default C3 Engine Removal
Hi, what's the best manual available for step by step engine removal of a C3 (1981) engine???
Old Aug 16, 2017 | 03:27 PM
MelWff's Avatar
MelWff
the factory chassis service manual
Old Aug 16, 2017 | 03:56 PM
Alan 71's Avatar
Alan 71
Hi Don,
Welcome!
First post!
The engine removal information is in Section 6 of the GM Chassis Service Manual.
In the 71 CSM it's in 6-27.
Do you happen to have the CSM for your 81?
Regards,
Alan
Here's what the 80 CSM looks like.
Old Aug 17, 2017 | 11:11 AM
don1947's Avatar
don1947
8th Gear
Default C3 engine removal
Originally Posted by Alan 71
Hi Don,
Welcome!
First post!
Regards,
Alan
Hi, no I don't have one! Where should I go to find one? Any suggestions would be appreciated!! Don
Old Aug 17, 2017 | 11:46 AM
Alan 71's Avatar
Alan 71
Hi Don,
I see that Corvette Central has the 1981 GM Service Manuals listed.
So you might begin by checking with them.
The engine removal section/info is in the earlier manuals BUT I'm not positive if it's in the later manuals….I'll keep my fingers crossed.
Even if the removal info isn't in the 81 Manual I think you'll find it useful.
If it's not there I'll copy my pages and send them to you.
Regards,
Alan
Old Aug 17, 2017 | 01:22 PM
kingkohlmn's Avatar
kingkohlmn
Veteran: Marine Corps
Hi Don,
If you're going to work on you car, there are two manuals which are an absolute must to have. The GM service manual and the assembly instruction manual (AIM). The GM service manual will most likely cover other cars also, it's just what they did with the later C3's. Don't go with the Haynes manual, it is not the same. You're starting off on the right foot by using this forum. The knowledge here is incredible and has help more times than I remember. Good luck, Bill
Old Aug 17, 2017 | 05:25 PM
don1947's Avatar
don1947
8th Gear
Default Engine removal
Hi Don,
Regards,
Alan
Thanks !! I will certainly call them first! Thanks
Old Aug 17, 2017 | 05:29 PM
don1947's Avatar
don1947
8th Gear
Originally Posted by kingkohlmn
Hi Don,
. Thanks Bill, I will check on them both. I have had this car since 1985. Finally retired and have some time to start doing some things!
Old Aug 17, 2017 | 09:08 PM
rberman999's Avatar
rberman999
Hi Don,
Check eBay for the factory service manuals. If you look you should be able to pick one or even the whole set up for roughly $25 give or take a few bucks. May also be able to find an assembly manual as well. These would likely be used manuals. I got my GM factory service manuals there as well as the GM corvette parts manual and exploded diagrams. Lots of luck. Russ
Old Aug 17, 2017 | 09:09 PM
don1947's Avatar
don1947
8th Gear
Happy
Hi Don,
Regards,
Alan
To C3 Engine Removal
