Method of supporting trans to frame with engine out?
I am putting my 69 frame back together. I have the suspension on and rear end in, but would like to put in the trans (loosely for now). Is there a way to support the front of the trans from the frame so I can roll everything around on the wheels without the engine in?
Glenn in San Diego
Glenn in San Diego
Received 2,878 Likes
Hi Glenn,
The transmission isn't all that heavy…. especially when the tail shaft is supported.
I ran some heavy rope from frame rail to frame rail running under the transmission case. I believe, to be sure, I went across 3 times.
I didn't think I'd ever have to admit doing that.
I actually ended up taking the transmission back out when I put the engine in place.
Regards,
Alan
Regards,
Alan
