Electric oil gauge conversion question
Old Aug 19, 2017 | 10:06 PM
RJ1AZ's Avatar
RJ1AZ
From: PHOENIX, AZ Yes, it's true. You are a good woman. Then again, you may be the Antichrist.
Default Electric oil gauge conversion question
Quick question for those of you who have converted from a mechanical oil gauge to an electric.
Where did you tap into for the power feed? I'm thinking I can just run a wire with a ring terminal to the post that the pink wire for the fuel gauge is attached to.
Suggestions?
Thanks,
Rick
Old Aug 19, 2017 | 11:10 PM
Richard454's Avatar
Richard454
Yep- that'd be the power source you want to use. It's not powered when in acc and it's powered when the starter is spinning.
Richard
Old Aug 19, 2017 | 11:19 PM
7T1vette's Avatar
7T1vette
Just jumper it to 12 vdc feed for another gauge.
Old Aug 21, 2017 | 08:16 AM
Richard454's Avatar
Richard454
That's the pink wire...it's used for the water and fuel gauge - which is fused in the fusebox - ironically - labeled "gauges."
You would not want to use the ammeter or clock-
Richard
Old Aug 21, 2017 | 10:45 AM
7T1vette's Avatar
7T1vette
I guess you could call the clock a 'gauge', but that wasn't my intention. The "engine performance instruments" [better?] don't function until the ignition key is turned to ON. Power for them is where you get the 12 vdc [operating] power for you oil gauge.
Old Aug 23, 2017 | 01:05 AM
RJ1AZ's Avatar
RJ1AZ
Ok guys, thanks for your input.
Next question. Looking at the rear of the gauge, I've got the left post hooked to the sender wire, the right post hooked to the pink wire post for the fuel gauge, and the center post is to ground.
Key on to acc, gauge pegs to zero. Key to start, gauge sweeps up to 80 psi and stays there, regardless of rpm.
I'm thinking maybe the sender is not grounded? I believe I used some Teflon tape when I installed it, so maybe that's interfering with it grounding? Sender is new, so I'd be surprised if it was bad.
Old Aug 23, 2017 | 08:11 AM
7T1vette's Avatar
7T1vette
That's a possibility; or the wire connections should be different. Did you get any instructions with the gauge?
If it is a stock-type Corvette gauge, Willcox has some good documentation on how the various gauges should be connected.
Old Aug 23, 2017 | 11:30 AM
Richard454's Avatar
Richard454
The teflon tape's purpose is to fill any gaps between the threads and reduce friction during tightening. The NPT will cut through the teflon and not prevent a ground.
When you say " Key on to acc"- you mean ignition- correct?
Key to start- while the starter is turning- or just running?
Depending on the gauge- OEM had a 90Ω resister between the +12V ignition (pink wire) and the sensor. Reproductions don't use the resistor. (top pic)
The 9 O’clock terminal would be your ohms input terminal from the sender, the 3 O’clock terminal would be your power. The 6 O’clock terminal is the ground to the housing. The scale of this gauge is just like that of the fuel gauge, 0 ohms is zero, 45 ohms is 40lbs and 90 ohms is 80lbs.
I would disconnect the sensor wire-turn on the ignition(don't start the car)and see what you read. Then jump that sensor wire to good ground and the gauge should read 0.
let us know.
Old Aug 24, 2017 | 01:08 AM
7T1vette's Avatar
7T1vette
Well, those NPT threads SHOULD cut through the Teflon tape. But, there is enough anecdotal evidence that folks who have used Teflon tape have had a few problems. Whether the threads cut through it or not would be a function of how many rounds of tape were used and how much torque was applied to the sending unit.
As Teflon is a very good insulator, it might be best to remove it and just use some pipe dope to seal the joint.
Old Aug 24, 2017 | 07:56 AM
Richard454's Avatar
Richard454
Sorry.....Pipe threads are sharp.. teflon acts a a lubricant- it'll cut right through it. Don't have to believe me- "JohnZ" has a lot more knowledge than I...
Read this- actual testing of the teflon myth-
http://www.stl-vettes.com/65Vette/co..._and_Gauge.pdf
Old Aug 24, 2017 | 08:08 AM
chstitans42's Avatar
chstitans42
TheCorvetteBen
Thanks for making this thread! Ill be converting my oil pressure gauge today!
Old Aug 24, 2017 | 10:53 AM
7T1vette's Avatar
7T1vette
#1 I don't believe that you could get a pipe plug to even start into a threaded hole if it had 20 rounds of Teflon tape on it.
#2 I am always doubtful of ANYONE who states that something will ALWAYS occur.
#3 It is nice that you are so convinced that such could not happen. Don't expect the rest of us to have that same level of confidence just because you do.
Old Aug 24, 2017 | 02:42 PM
Richard454's Avatar
Richard454
Ok..so maybe it was only 15- what's the point....didn't change the reading
Where did I say "always?"
That comes from giving the OP a couple of steps to do-a diagram and numerical data to isolate/diagnose the problem- not a random remote* possibility....
*Quote from "JohnZ" above...
Old Aug 24, 2017 | 05:49 PM
7T1vette's Avatar
7T1vette
Richard, you are the one trying to convince folks that putting Teflon tape on pipe threads is 'no big deal'...even when that item is supposed to pass electrical ground. I'm just offering that may not be the best alternative.
Old Aug 24, 2017 | 06:48 PM
Richard454's Avatar
Richard454
And that's your opinion- I at least follow up with some tests to prove otherwise.
Richard
Old Aug 26, 2017 | 11:43 PM
RJ1AZ's Avatar
RJ1AZ
Connections at the gauge are good (sender to 9 o'clock, power to 3 o'clock, ground to 6 o'clock).
I used my multimeter to check continuity from the engine block to the exterior of the sender, and that was good. The sender is grounded to the block.
I turn the ignition to the first click. No reaction from the gauge. Second click to where power is on, gauge pegs to zero. Turn to engage starter, engine running, gauge sweeps over to a little past 80 psi.
I guess my next step is to check the ohms coming from the sender.
Old Aug 27, 2017 | 08:14 PM
theandies's Avatar
theandies
I prefer my mechanical gauge. I trust it, it works great and it's a true indication of oil pressure.
To Electric oil gauge conversion question
Old Aug 29, 2017 | 01:05 AM
RJ1AZ's Avatar
RJ1AZ
I'm glad it works for you. I prefer electronic. It will never leak oil all over my radio like the mechanical gauge did.
Old Aug 29, 2017 | 03:35 AM
theandies's Avatar
theandies
Although it's not 100% but since I installed AN fittings and a braided steel oil line it's probably 99% that it will never leak AND I know that what is on my gauge is what is going on in my engine. No guessing at all and no DMM needed.
Glad your conversion is going so well for you.
Old Sep 11, 2017 | 12:29 AM
RJ1AZ's Avatar
RJ1AZ
Finally got this figured out today.
All connections seemed right and I had verified the sending unit was grounded to the block. Gauge was functional, just not reading correctly and the reading would not fluctuate with engine rpm.
I pulled the old sending unit off off my '75 coupe and installed it on the '69. Fired up the engine and voila! The gauge works fine. I installed the new sending unit on the '75 and that gauge exhibited the same problems as described before. So, lesson learned...brand new sending unit is JUNK!
Glad to have this mystery finally solved so I can get my dash put back together.
