Headlight troubleshooting
Old Aug 29, 2017 | 08:00 PM
Tguns's Avatar
Tguns
2nd Gear
Default Headlight troubleshooting
Hi everyone. I recently purchased my first Corvette. It is a 1974 w/ t-top, 4 speed, aftermarket heads, intake, and suspension. It is in great condition inside and out. Trouble is, after using the headlights 3 or 4 times they will not go back down. I can manually put them down, but each time I start the car they raise if I do not have the actuators disconnected. I think it may be an issue with either of the switches. I do have a mityvac and am just looking for some advice. Thanks
Old Aug 29, 2017 | 09:48 PM
Dave J's Avatar
Dave J
Here's a really good place to start.
https://www.corvetteforum.com/forums...tem-works.html
You will learn how the system is supposed to work along with how to troubleshoot. Your Mityvac will come in very handy. Concentrate on the headlight relay and actuator seals.
Old Aug 29, 2017 | 11:57 PM
ntfday's Avatar
ntfday
Veteran: Marine Corps
I replaced the actuator and switches and the pull down switch on my 76. I also replaced the headlight switch and a few feet of hose.
Old Aug 30, 2017 | 07:26 AM
SPCL FX's Avatar
SPCL FX
Try Corvette 101.com
I checked my whole system with their info and great diagrams !
Learned about it from someone else on the forum!
Old Aug 30, 2017 | 07:57 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Tguns
...each time I start the car they raise...
Check the headlight over ride switch beneath the steering column.
Old Aug 30, 2017 | 07:04 PM
Tguns's Avatar
Tguns
2nd Gear
Thanks for help! I have become very familiar with the whole system over the last few days! I thought the override switch might be the problem. That corvette 101 guide is just what I needed.
To Headlight troubleshooting
