Another headlight question
Old Sep 1, 2017 | 11:21 AM
sullyman56's Avatar
sullyman56
Default Another headlight question
I'm trying to get the headlights working on my 68 and came across what I believe to be a problem with the actuators. I've read all the troubleshooting threads and can't find an answer. All the vacuum lines are new and run according to the AIM. When I pull the headlight switch or use the override switch nothing happens. I'm pretty sure the tank is ok because after I shut it off and pull the headlight switch I can hear the relay working. I did find one seal torn on the front of the right actuator so I know that needs attention. The left one seems ok and holds vacuum when I tested it with the mightyvac. Since the relay functions correctly when the switch is pulled and nothing happens, could it be that I need to repair or replace the actuators? Any help with this will be greatly appreciated. Thanks in advance.
Old Sep 1, 2017 | 12:35 PM
henrikse's Avatar
henrikse
do they operate with handheld vac at relay or actuator up or down?
