Shift indicator?
Old Sep 4, 2017 | 10:41 PM
Silver72's Avatar
Silver72
Default Shift indicator?
Is there no indicator what gear you are in, in a '72 automatic?
Hopefully this post does not fail the mantra, "There is no such thing as a stupid question."
Had fun removing the trim plate today. Had to learn the hard way that once you remove the 4 screws the plate does not simply lift straight out.
Old Sep 4, 2017 | 10:52 PM
san's Avatar
san
Default good question
I have a 78 and was wondering the same thing...why would there be a light in there and no indicator??? Ive seen some pics of models that do indeed have a little orange needle showing shifter location....anyone know for sure?? Was it an option??
Old Sep 5, 2017 | 12:13 AM
The13Bats's Avatar
The13Bats
The little pointer was added in 77,
http://repairs.willcoxcorvette.com/1...-installation/
Old Sep 5, 2017 | 08:43 PM
loup68's Avatar
loup68
Army
Hey, there is not shift indicator on a four speed! LOL Lou
Old Sep 5, 2017 | 08:45 PM
Silver72's Avatar
Silver72
Ok, maybe it would be easier to convert to a 4-speed vs trying to figure out what gear I'm in. Sounds like a good weekend project!
Old Sep 5, 2017 | 10:41 PM
riverracer au's Avatar
riverracer au
my '72 does.... now
https://www.corvetteforum.com/forums...indicator.html
i'm at work and we're blocked from pics, so not sure if photocrap has removed photo links yet?
can pm them if you like?
Old Sep 5, 2017 | 11:04 PM
gbvette62's Avatar
gbvette62
68-76 automatics didn't have an indicator or "pointer", you just line the shifter up next to the letter or number, on the console plate.
All 77-82 automatics had an indicator. It's white plastic and is moved by a little tab on the shifter. They seem to get caught or bound up occasionally, and then break off when the shifter is moved. The indicator is reproduced and sells for about $8, but you need to remove the console to replace it.
Old Sep 6, 2017 | 08:10 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Silver72
...trying to figure out what gear I'm in...
I may be missing the point, but if you are not in reverse or neutral, the tranny is probably in drive.
Old Sep 6, 2017 | 11:08 AM
kenba's Avatar
kenba
From: PHOENIX AZ. WHAT A MAN WON"T SPEND TO GIVE HIS ASS A RIDE
So some here can't figurer out how to shift a automatic without a idiot light. Maybe your not Corvette worthy and please stay away from 4,5, & 6 speeds where you need to use your left foot.
Old Sep 6, 2017 | 11:49 AM
chazde3's Avatar
chazde3
Is being rude really necessary?
Old Sep 6, 2017 | 12:47 PM
7T1vette's Avatar
7T1vette
I would have been more polite, but knowing which gear you are in with a 3-speed automatic tranny is not rocket science.....
Would it appear nicer with a shift indicator? Yes. Is one necessary? No.
Old Sep 6, 2017 | 04:55 PM
raydog9379's Avatar
raydog9379
The question likely stems from a simple why in the world did they not have that there when most cars do.
Answer is probably along the lines of GM saving a penny or 2, some engineer didn't think it was needed at the time, or thought that it was neat to just line up the shifter with the position. Then it was added in after several people probably complained, someone sued GM, or they thought it enhanced that luxury feel, or whatever.
Old Sep 6, 2017 | 07:19 PM
general ike's Avatar
general ike
2017 C3 of the Year Finalist
St. Jude Donor '20- '21
Well do you need it >>>NO. Should it be there>>>YES. Its just odd, I thought maybe it fell off or something. I cannot believe that to save a few pennies, they would leave it of. There are quite a few things that GM did, I guess to save a few pennies that make no sense. I know all pennies count but I cannot believe that it would be worth the savings to its effect on the end product.
Is there even a light for the shifter indicator??? I have seen mention of it, but I didn't see it in the Aim manual and there is none illuminating on my 1972 coupe. Is it just out? I took a quick peak a while ago and didn't see any bulb there. Anyone? Thanks Ike
Old Sep 6, 2017 | 09:22 PM
7T1vette's Avatar
7T1vette
Yes, there is a bulb in the housing below the shift indicator.
Old Sep 6, 2017 | 09:48 PM
Silver72's Avatar
Silver72
Originally Posted by riverracer au
my '72 does.... now
You win the ingenuity award! I can only imagine what else is lurking in your '72. :-)
Old Sep 6, 2017 | 10:00 PM
gbvette62's Avatar
gbvette62
I don't really think that it was a matter of saving a few pennies. Most console mounted automatics in the 50-60's, didn't have any sort of pointer or indicator. 53-67 Corvettes, 61-64 Impala SS', 64-67 Chevelle SS', etc, didn't have any indicator or light. The Corvette's console was designed in the late 60's, when most cars with a floor shift didn't have any sort of indicator.
Cars with floor mounted automatic shifters, weren't all that common in the 60's, and I don't think an indicator was considered necessary.
Old Sep 7, 2017 | 10:17 PM
general ike
Hello all, I don't mean to hijack this thread but I have been unable to find any notation in the Aim manual that a 1972 had a light at the shift indicator. Does anyone have a pic of the light bulb in the location or a page/diagram from AIM??? I am wondering if the wire is missing or hiding in there. Greatly appreciated!!!!! Ike
To Shift indicator?
Old Sep 8, 2017 | 02:05 AM
Haggisbash's Avatar
Haggisbash
I often wondered why the position indicator was on the passenger side the trans rather than the driver side. A PO went to the trouble of mounting a light onto the shifter and put indicators in the console in my '70
The white label was a temp fix I used for position indication when the four speed went in.
Old Feb 21, 2019 | 10:10 PM
Hig116's Avatar
Hig116
Ike,
Did you get an answer to this question? I just pulled apart my console and see where it looks like a bulb should go, but no light is wired to it. Not sure if its not hooked up, missing or something else. Can you tell me what you learned?
Thanks,
Keith
Old Feb 21, 2019 | 11:55 PM
Haggisbash's Avatar
Haggisbash
Hi, the whole thing in my '70 was custom, since I've changed to a four speed auto I elected to put a label you can buy on line on the RH side of the shifter. No way to put a light under it because of the ash tray door so I did without it. What year is your vette?
