Aftermarket fuel injection questions
Your opinions and recommendations will be appreciated.
Working on a 69 sbc coupe.
Which system do you have?
Are any other modifications required?
Does OEM filter housing fit?
Is the OEM fuel return line sufficient?
What fuel pump, in-line is it noisy? Or in tank, how hard is that?
What about the tuning?
Thanks in advance. T
Which system do you have? - Fitech Go EFI4
Are any other modifications required? - No
Does OEM filter housing fit? - Pretty sure it does although I don't run the stock air cleaner
Is the OEM fuel return line sufficient? - Yes, uses your stock fuel pump that feeds the Fuel Command Center.
What fuel pump, in-line is it noisy? Or in tank, how hard is that? - See above, or you can use an in-tank or inline electric. I really like the FCC and I haven't had a lick of problems with it.
What about the tuning? - It's real easy and its self learning. Just follow the basic destructions to get yourself started then fine tune to your liking.
FItech 600hp. Running a tanks inc fuel tank with a with an internal fuel pump.. i used the factory fuel line as a return line to the tank. Using -6 hose for supply. Lots of ways to accomplish the job, just the route I took. Yes, its worth the effort.
