No replacement for displacement.
just buy 1 of my 588'' engines, only dyno time,alum heads 1150 holley dom carbs,.724'' lift full roller setups,bowtie blocks,cola stroker cranks,manley h-beam rods,750hp at 5200 rpms [with lots to go] on pump gas
Ray
I stuck with the plan of building a budget Rat found on Craigslist. Feeling Like my small block cars just don’t have the torque that the Corvette has. I now have everything needed stem to stern to put it together. It came in at just a hair over 4 grand and is expected to put out north of 500hp. I wanted more H.P. but the cost goes way up past 500 and after all, this is on a budget.
Machine work is outstanding, Thank you Rob. Here are some pics of the block and heads sporting fresh VHT Chevy orange.
At the shop waiting for the trans to be rebuilt and installed on the block before I picked it all up.
Attachment 48345903
All installed back into the '68. Waiting on me to finish up additional work before the first test drive, but did a light break in at 2000rpm for a half hour or so.
Attachment 48345904
oh common... that's not fair to BBC's... it's like a 12ga when you know there are 8ga's out there... poor big blocks getting called a 20ga... >.<
im not... although I LOVE a bbc… I HATE working on one by myself... which is 99% of the time... i'll take the manageable 300lbs tyvm
Year car, body style, and in this case the engine can and does cause that.
Re re reading this 2017 thread and what i wrote back then my feelings have only intensified,
My 454 was sadly tampered with, it will need to be gone through and being ADD and OCD it drifted into my mind should i just go small block and i quickly knew for me no way, it would feel like settling, like something was missing.
Sure there will be small blocks that can spank my bb but they will have much more money in them than i do my bb,
I do like being able to say yes, my corvette IS a big block,
So if all a person wants or needs or desires is small block i support that for them but this thread is about bbs and i for one get it...and have mine
