T5 5 speed
Old Sep 10, 2017 | 12:08 PM
750green's Avatar
750green
Default T5 5 speed
Need some help. Currently have a t5 in my 80 with a z-bar. Found a good deal on a hydraulic bell housing with hydraulic pedals out of and 82 camaro. Anybody know if the pedal and break assembly would like up with the master cylinder?
Old Sep 11, 2017 | 09:19 AM
750green's Avatar
750green
Anything dudes?
Old Sep 16, 2017 | 03:47 PM
Evren Erdogan's Avatar
Evren Erdogan
Originally Posted by 750green
Anything dudes?
hi dear im also putting a hydraulic master on my 79 vette we all know one from 85 gm truck fits in perfect angle and they are 16 dolars and slave cylinder is about 25 bucks .i compared the 2 clutch master cylinders just looking at the pics for ya. 82 camaro's mounting bolt on the master looks like way more tilted.hope this helps
Old Sep 17, 2017 | 10:14 AM
righthanddrive's Avatar
righthanddrive
I believe the camaro bell housing transmission mounting holes are clocked a little toward the driver also
Old Sep 19, 2017 | 03:00 AM
AboveTheLogic's Avatar
AboveTheLogic
Yeah just run the '85 full size truck master cylinder with a wilwood remote reservoir ($24) and call it a day.
The hardest part is finding the right fittings for the master to the slave. I have some details in my thread here:
https://www.corvetteforum.com/forums...post1592488632
Old Sep 19, 2017 | 04:49 AM
Evren Erdogan
i read ur nice write up .i guess u used hydraulic tb.i have bought everything from summit for slave cylinder type for 85 truck and also bought the line hose between master and slave i hope i like how the hard line hose installs .i was also thinking about universal line .glad u mentioned it did not have the correct fitting in the set .emmm i bought the clutch pedal set but there is no bushing on the master cylinder rod connection .what did u use for master rod bushing?
Old Sep 19, 2017 | 10:36 AM
AboveTheLogic
In my case, the end of this heim joint slipped right onto the factory clutch pedal link:
Attachment 48354408
Old Sep 20, 2017 | 04:21 PM
Evren Erdogan
i forgot to ask why we cant use a reservoir from 85 truck .its cause they dont sell them or what?is it the same size from master to reservoir fitting? Thanks again
Old Sep 21, 2017 | 01:08 AM
AboveTheLogic
I suppose you can use any reservoir that fits. I don't know what the original one is like. I just used the wilwood one because it was easy to find and not too expensive.
Old Oct 5, 2017 | 02:23 AM
Evren Erdogan
Everything went nice and easy i welded the rod of the clutch master made it adjustable but the booster does not seat too well .luk clutch master's reservour fitting touching it
Old Oct 6, 2017 | 05:34 PM
cv67's Avatar
cv67
St. Jude Donor '05
damn wish I knew that yrs ago
Originally Posted by 750green View Post
Anything dudes?
hi dear
Old Oct 6, 2017 | 08:34 PM
Evren Erdogan
Mm
i used 85 trucks master but the nipple on luk brand is high enough to touch the booster.i checked out someone used wagner master which has a shorter nipple head and seats perfect with enough clearance 20 bucks.i need to put a clutch stop under the pedal .since master bottoms out at an inch to the floor on 79 vette thank u
Old Oct 7, 2017 | 01:42 AM
AboveTheLogic
I just flipped it over so the nipple faced down. Works fine.
To T5 5 speed
