Another wiper problem.
Now I connected the dk blue, black with white stripe and lt blue to the switch. Thats left to right. The dk blue has power when the key is on and the lt blue also has power. The black/white has power when you move the switch over. I also have the dash piece the switch is mounted on grounded. If it isn't grounded the relay dosen't click when you move the switch. I added a new engine harness so the wiper motor wires are new. The wiper motor has power to the lt blue and yellow wires all the time. When I put my test light in the there to check the wires for power I get a click from the wiper motor.
I can't seem to get the wiper motor to work. I am also pushing the switch for the door on the firewall in. Also what does the solenoid by the tach do with out any vacuum to it.
The wipers should work as the only wires that got disconnected on the inside were the switch wires and when I replaced the harness. Whats supposed to be hot with the key on and whats not. Also what do I have to do to get the wipers to work with out the wiper door on.
I have done some searches and checked wilcox's articles. It just dosen't seem right that the wiper motor has power there all the time.
I just started to look at the wipers so I didn't really dig into it.
I have a long hood that eliminates the wiper door and switches there. Had a heck of a time figuring out what needed to be jumpered and what did not when I replaced the harnesses.
I have his diagram printed out.
Above. I have it like the picture. When I got the car it had the wrong wiper motor in it and a the PO had added a ground to it.
First, the wiper switch is not passing power, it is passing ground. When the switch is off, the black/white wire should be grounded and the light blue should not be grounded. On low speed, both the black/white and the light blue wires should be grounded, and on high speed only the light blue wire is grounded. (The dark blue wire is grounded only for the washer pump)
One tip: run a separate ground wire to the back of the wiper switch. This missing ground (should be through the gauge console) is a common issue on our cars. Then, when you are moving between low/off you should hear the wiper relay click on and off.
On the wiper motor, the center wire (yellow) should have power with key on. The red power wire on the motor should have power all the time as long as
1. the wiper door is up (so the wiper door limit switch is closed) and
2. the dash override switch is closed.
This red wire is what you need to connect to 12V to bypass the wiper door.
This is perfect. I got up early and was out in the garage and got everything working.(I hope) Then I came in and saw your post. I went thru the Wilcox tapes(sounds like a spy movie)and figured out how everything works. Grounded the wiper switch and put a clamp on the switch for the door and everything worked.
I appreciate every ones help. Thanks guys.
