decypher numbers on block
Always thought that the previous owner changed the block in my 1978
l-82 motor
checked the block and found the numbers on the pad in front of right passenger valve cover...there was a large set and below that a smaller set... the large set were K0104DPH can anyone decypher this..??
my eyes arent as good as they use to be so Ill nee a magnifyin glass to read the smaller second line and the post for help decyphering
'thank you
Brian
l-82 motor
'thank you
Brian
Received 1,469 Likes
Cruise-In II Veteran
K is the plant code for St. Catherines, Ontario, Canada. 0104 is January 4th. I cannot find DPH. What you have is probably a Chevelle or Camaro engine. It is not Corvette. The smaller number on the pad would be the VIN derivative of the car the engine was originally installed in.
You may want to take another look at the "DPH" or post a pic.
Some possibilities,
CPH - 1980 267c.i. 120h.p. 2bbl auto trans.
D5H - 1983 305c.i. 145h.p. 4bbl Roch E4ME carb
D8H - 1981 267c.i. 120h.p. 2bbl E2ME carb ex Calif
DRH - 1979 350c.i. 170h.p. 4bbl auto trans
Some possibilities,
After a closer look ...it is ....K0104DRH
Still trying to get a good read on second smaller line...
"DRH" is a 350/170 out of either a 79 Camaro or full size Chevrolet (Impala/Caprice).
