Choke Part Number (GM)
http://www.zip-corvette.com/70-454-7...ke-spring.html
Thanks!
PS: Looks to me like the rod hook up is about at 5 O-clock right?
I ordered on from an online vendor and received one with the rod hook up at 3 O-clock.
The number stamped on the original bi-metallic spring from my 71 is 3792.
My bet would be that you can use the one that you received.
Hooking up the rod will 'tighten' the coil a little, but the heat will still have the same affect on it... it uncoils as the temperature rises and the rod will open the choke plate.
Regards,
Alan
I just manually wound the spring a bit tighter, and when it relaxed it came back to 4 O-clock. One more try (a bit harder) and it relaxed to 5 O-clock where it belongs.
-W
