Paint vs powdercoat?
This is the 69 frame I recently restored. Sorry for the dust on the frame.
Attachment 48210717
As a manual frame it had a fixed cross member for the transmission. This modification makes it removable making installation and removal of the transmission much easier at a later date.
Attachment 48210718
Front view of the same frame. Sorry for the dust on the frame.
Attachment 48210719
Reinforcements added forward of the kick-up area. Welding reinforcements and stiffening.
Attachment 48210720
Front extensions replaced to remove pitted areas. Much nicer now.
Attachment 48210721
Front cross member repair section (removable) to reinforce the area where many jack up the car. This eliminates the denting up there and it is removable if you want to repair it. Area under it was also powder coated.
Attachment 48210722
The powder coating won't cover pitting in the frame but I am not an advocate for filling frame pitting anyway, like trying to cover up the pitting to hide something. Yes, looks better, but not really representative of the frame integrity.
Attachment 48210723
As long as you have the frame bare take some dimensions too and maybe gauge block it to make sure you have no twist or torque in the frame. An ounce of prevention so to speak.
Good luck with your decision.
David
