proper fuse for window operation
Old Oct 4, 2017 | 03:41 PM
ballen06's Avatar
ballen06
Default proper fuse for window operation
1969 corvette L46
My electric windows are not working. Both sides.
Can someone tell me which fuse is associated with the windows.
I'm hoping that is the problem. For me anyway it is very difficult for me to access the fuse box so I would like to just go for the correct fuse and replace it rather than try to test each one.
Thanks for your help.
Old Oct 4, 2017 | 04:13 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
IIRC, there is a circuit breaker for the windows under the hood.
Old Oct 4, 2017 | 08:00 PM
ballen06's Avatar
ballen06
Thank you Mike... I had no idea.
Old Oct 5, 2017 | 02:17 PM
ballen06's Avatar
ballen06
1969 corvette L46
I assume the photo below is the circuit breaker. Correct?
If it is how do I determine if it is working properly? Continuity between the two terminals?
Old Oct 5, 2017 | 02:37 PM
Alan 71's Avatar
Alan 71
Hi b,
The Chassis Service Manual indicates there's a connection at the fuse panel and at the horn relay for the power-window harness.
There appears to be an additional relay and ground connection under the shifter console.
You might check all those too.
Regards,
Alan
Old Oct 5, 2017 | 04:05 PM
ballen06's Avatar
ballen06
Originally Posted by Alan 71
Hi b,
Regards,
Alan
OK... Thanks Alan... I'll check those components out.
To proper fuse for window operation
