1981 Original Decal Placement
Thanks!!
Thanks!!
To start with, the majority of 81 Corvettes didn't use the "Unleaded Fuel Only" label. On most 81's the words Unleaded Fuel Only are molded into the gas door bezel, and are only visible when the gas door is opened. Some VERY early 81's, maybe the first 4000, used the unleaded label, but after that it was replaced by the bezel with the warning molded into it.
Under hood, there is a yellow "Caution Fan" warning label centered on the top of the shroud, placed so that it can be read from the rear. The cap on the overflow bottle has a label that says "Notice" in white on a blue background, and black lettering that reads "Engine Coolant Only". The emission label is placed on the driver's side of the underside of the hood, along side of the hood frame and just forward of the hood latch. One master cylinder bale has a label marked with a "YC" in red letters, and Bowling Green 81's had a bar code label on the outer side of the master cylinders. Brake boosters had a small white label on the top front of them, with a two letter broadcast code on it.
The air cleaner has a "Keep Your GM Vehicle All GM" label centered on the driver's side of the air cleaner base. The right (passenger side) valve cover has a round, black crossed flags emblem on it. The valve covers also had an engine code label placed on either the front or back of the covers. These labels had two letters and/or a bar code on them, to identify the engine. Various engine components had bar code labels on them, but none of the valve cover or the bar code labels are being reproduced. The alternator had a black, ink stamp, broadcast code on it. The AC compressor label is placed on the top of the widest diameter portion of the compressor, placed so that it can be read from the rear.
The driver's door has a two part "Certification Label" placed on the inside top of it, an inch or so above the door latch. The underside of the jack compartment door had one to three labels placed on it. All 81's had a two part jacking instruction and caution label, on the underside of the door. If the car came with optional aluminum wheels, it had a caution label about the wheels, and 81's with the fiberglass rear spring, included a third blue and white label about the spring. The jacking instructions are available as a repro, but not the aluminum wheel or fiberglass spring labels.
There were also labels placed on each of the shocks, both front springs, and on the underside of the rear fiberglass spring. I think these are all of the labels used on an 81.
Again, thanks.
