Heater core rebuild, need some help
Old Oct 26, 2017 | 03:10 PM
Stingre''s Avatar
Stingre'
Default Heater core rebuild, need some help
What better way to spend the day than to do a heater core rebuild, everything going ok until I got to this broken plastic part. I've spent more time trying to find a replacement than I have on the rebuild. Anybody know what this part is called? Thanks in advance for your support
Old Oct 26, 2017 | 05:46 PM
TimAT's Avatar
TimAT
Check your PM's
Old Oct 26, 2017 | 07:46 PM
lvmyvt76's Avatar
lvmyvt76
check with Dr Rebuild for part
Old Oct 28, 2017 | 10:28 AM
caskiguy's Avatar
caskiguy
What year ?
Old Oct 28, 2017 | 10:58 AM
caskiguy's Avatar
caskiguy
http://store.bigcitycorvettes.com/pr...1977-Only.html
Old Nov 26, 2017 | 08:28 AM
caskiguy's Avatar
caskiguy
Did you ever find the Air diverter door actuator ? If not WillcoxCorvette.com has one in their used part section fits 68-82.
Good Luck
Old Nov 26, 2017 | 09:17 AM
derekderek's Avatar
derekderek
in another thread a guy just made a metal strap and put it over it. probably an improvement on the design, but you should use beer can in the spirit of that guy bubba...
Old Nov 26, 2017 | 12:39 PM
fever1's Avatar
fever1
Thats what I did the older chevy pickups used the same part I have a 76 chevy pickup and it has the same thing.
Old Dec 12, 2017 | 05:36 PM
RocketNerd's Avatar
RocketNerd
I just got my C3 a few weeks ago and tore it down to the firewall to start rebuilding, since i was there i was planning on doing the heater core as well, so as to keep from leaking after I get the dash back together and install new carpet (Murphy's Law). I have the same tab that is broken on my heater box defrost/vent selection door. It was obviously repaired in the past (gobs of glue all over) but haven't been able to find that small part anywhere. I was planning to take some measurements and 3D print one this weeked, it should only take about an hour to do so, and with some fiddling ensure everything fits right. I'll make it out of high temp ABS, so I'll keep you updated if it works, and if you'd like i'll send one to you.
To Heater core rebuild, need some help
