There may already be a thread out there that I can't pin down, but has anyone done a recent (as I know they have gone through some fairy significant upgrades over the past few years) EFI conversion to their vette
I am mostly drawn to the FiTech system since it is the only system that has the command center, therefore negating the need for a return line which would make the install much easier -- which is important since I am planning on doing the install myself.
I currently have a newly rebuilt 383 in my 71' (still has less than 500 miles on the rebuild) with a 600 CFM carburetor which is undoubtedly restricting my power gains so a upgrade to either a larger carb, 750CFM, or a EFI is inevitable...thoughts/ experiences would be appriciated???
I haven’t installed the Fitech setup, but I have been interested in an efi for a while. It appears as though you should stay away from the command center.
I've got the Terminator efi. I would have gone for the sniper as it's a more simple install. I use the original hardline from tank to terminator. At the rear I have the C5 FPR.
So install is TBI - FI hose - hardline - FI hose - C5 FPR - 1 bend hardline to the pump and 1 bend hardline to the return. I used the Tanksinc FI conversion tank. I don't think it gets much simpeler.
Currently I'm swapping the C5 FPR with a Holley regulator to lower the pressure. I know the FPR at the rear is not ideal but the fuel pressure with the C5 FPR was stable so I assume it will be with the Holley.
If you go with the sniper, you will need to run a return from the engine compartment to the rear
Nick
This is a handy comparison chart. For me, I wanted an integral ECU to simplify the wiring and for it to be completely self-tuning (which isn't shown in this chart).
