74 Corvette question
Old Nov 8, 2017 | 03:54 PM
belairbrian's Avatar
belairbrian
Default 74 Corvette question
Quick question.
Other than the "Z" in the VIN and serial numbers,anything else should I look at to verify it's a factory 454?
I've owned two L48s but no big block Vettes.
Old Nov 8, 2017 | 04:05 PM
derekderek's Avatar
derekderek
first would be 7 valve cover bolts instead of 4... the Z in 2nd digit means corvette. W in 5th digit is 454 K and L are the 2 350's.
Old Nov 8, 2017 | 04:24 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by belairbrian
...anything else should I look at to verify it's a factory 454?...
The engine pad stamps.
Old Nov 8, 2017 | 05:00 PM
Alan 71's Avatar
Alan 71
Hi bb,
Look here for the 2 engine stamps.
The engine assembly stamp which was done at the Tonawanda engine plant when the engine was assembled.
The VIN derivative which was done at St.Louis and indicates the vehicle the engine was first installed in.
Regards,
Alan
Here's an example from an earlier bb engine pad.
Old Nov 8, 2017 | 06:48 PM
derekderek's Avatar
derekderek
Bit if it is a W car, it is orig big block even if it is 78 truck motor. Better than a K or L car with 454.
Old Nov 8, 2017 | 06:49 PM
derekderek's Avatar
derekderek
My 75 vert is gonna be a numbers-matching 454. Number on hood gonna match the number on the air cleaner...
To 74 Corvette question
