Block numbers
Old Nov 14, 2017 | 11:41 AM
PHIL 68's Avatar
PHIL 68
Default Block numbers
Okay I admit I'm struggling to figure out system.If someone can tell me if my block matches my car I have a 68 vette base convertible with the 327 4 speed The number on rear of block is 3914678 and the front are 18S400436 V082IHE Thanks Phil
Old Nov 14, 2017 | 12:04 PM
71 Green 454's Avatar
71 Green 454
If your vin number is 194678S400436, then yes, I would say your block matches your car.
Old Nov 14, 2017 | 12:07 PM
avalonjohn's Avatar
avalonjohn
CF Community Team
Veteran: Marine Corps
St. Jude Donor '25
3914678 is the correct casting number for a 68 327. The latter numbers are a VIN and production / assembly date. Does your VIN end in 400436? If so, that is likely the original block (you have a VERY early 68). The second set of numbers "V" (Flint Mi.) "0821" or Aug 21st (1967 I assume), and HE is the engine suffix (327 / 300 HP 4Spd)
Old Nov 15, 2017 | 08:26 AM
PHIL 68's Avatar
PHIL 68
Default Numbers
Just trying to understand you say the 1st set of numbers show it to be a 68 but second show 67? thanks Phil
Old Nov 15, 2017 | 08:41 AM
Alan 71's Avatar
Alan 71
Hi Phil,
The engine assembly stamp indicates where, when, and in what configuration, the engine was assembled at the Flint engine plant.
All the dated parts going into building the first months of the 68 model year production were produced during the calendar year 67.
Parts were stamped with the date they were made… not what year car they were intended for.
No parts on a car should have a date AFTER the car was assembled at St.Louis, and TYPICALLY, have dates NOT exceeding 6 months PRIOR to the car's assembly date.
There are a few exceptions to the 6 month limit…. glass for instance.
Regards,
Alan
As an example… a car produced in February of 68….a 68 model year car…. could, and likely would, have a few parts on it dated late in the 67 calendar year.
Old Nov 15, 2017 | 10:52 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...Just trying to understand you say the 1st set of numbers show it to be a 68 but second show 67?...
Keep in mind new model year Corvette production usually began in August of the preceding calendar year. As an example, 1968 Corvette production began in August, 1967. Based on the consecutive unit number (436), your car was assembled during the first week of 1968 model production. This would have been a time after August 21, 1967 since the engine for your car was ordered from Flint Engine before your car was scheduled for assembly.
Old Nov 15, 2017 | 12:48 PM
PHIL 68's Avatar
PHIL 68
Thanks Allan and Mike that clarifies my confusion and also thanks to John and Green Phil
Old Nov 15, 2017 | 01:33 PM
derekderek's Avatar
derekderek
Does the 400436 on the block match the last 6 of Vin on title and windshield tag?
Old Nov 15, 2017 | 07:43 PM
PHIL 68's Avatar
PHIL 68
yes it does match Phil
Old Nov 16, 2017 | 06:16 PM
derekderek's Avatar
derekderek
then that engine has been in that engine compartment for 50 years...and a couple of months...
Old Nov 16, 2017 | 07:28 PM
PHIL 68's Avatar
PHIL 68
Perfect just what I was hoping to hear. Thanks Phil
To Block numbers
