Stripped caliper bolt hole
Old Nov 15, 2017 | 06:42 PM
Tim McNamara's Avatar
Tim McNamara
Navigator
Default Stripped caliper bolt hole
Hi all,
So I took the rear passenger caliper off my '80 vette because my parking brake isn't working and when I was removing the caliper I noticed that one of the caliper bolts was gone and rigged up with a like a carriage bolt or something inserted through the front of the hole and then a nut was screwed in on the back.
I can still see threads in the hole but they're pretty worn down and rusty. I was thinking about trying to tap it but not sure if that's the way to go. Any thoughts/suggestions?
Old Nov 15, 2017 | 06:56 PM
mortgageguy's Avatar
mortgageguy
Welcome to the board! You can try it. The good news, replacements aren't expensive.
Old Nov 15, 2017 | 07:18 PM
Tim McNamara
Navigator
Thanks. Do you know what size tap it would be? Also, I only have a parking brake assembly on the passenger side. Googling replacement parts...should there be one on the driver side, too?
Old Nov 15, 2017 | 07:51 PM
TimAT's Avatar
TimAT
There should be parking brakes on both rear wheels. As stated before, calipers are pretty cheap and available so changing one should not be a deal. If you're really committed to keeping those calipers, once you figure out what size the bolt is, you might be able to install a helicoil.
Old Nov 15, 2017 | 08:02 PM
Tim McNamara
Navigator
It's not the caliper that's stripped, it's the bracket the caliper bolts on to. I'd just scrap the caliper if needed but the caliper is fine. The bolt travels through a hole in the caliper and screws into the bracket and that's what's messed up.
and, I'll look into a helicoil. I've seen it mentioned a few times in other posts but don't have any experience with them.
Old Nov 15, 2017 | 09:16 PM
Wee's Avatar
Wee
If it's the same as a 72 it can be tapped....You have to use a button head bolt or at least I did....Not enough room to get a socket on the larger bolt head after tapping it to the larger size. Not the easiest job but it is doable. If someone else doesn't answer before tomorrow afternoon I'll look and see what size tap I had to use....Get a good one, the cheap ones will just break.
Brian
Old Nov 15, 2017 | 10:15 PM
bwbrown's Avatar
bwbrown
I was able to run a thread chaser tap into mine and remedy the problem caused by P.O. carelessness. Access really isn't too bad. Pull the rotor and caliper, use an 8 point socket and extension on the tap (my '75 was 7/16-20) - and plenty of tap lube.
But Corvette Central (and every other vendor) will sell you a caliper bracket. CC price is 46.00. It's a time consuming but not real difficult install.
If it can't be re-tapped, and 46 bucks sounds high... It's your BRAKES!!! When I repair something like this, I just imagine my daughter driving it - and make sure it is right - whatever the cost.
Good luck.
Old Nov 15, 2017 | 10:28 PM
GTR1999's Avatar
GTR1999
The caliper brackets are the same from 1965 - 1982. The thread size is 7/16-20, the bolts should have a shoulder on them, the same bolt used on the 1/2 shaft flanges to rear spindle flange. I find them from time to time rebuilding arms and many times they can be repaired. I do not increase the bolt size since I want to use the same bolts as came with the car. I do this repair with the bracket off the arm but that will mean you will end up rebuilding the arms. If the bearings are worn then it may be time but if they are still good and the overall arm is good then you might be able to repair it on the car or with the complete arm on the bench.
Here are some pictures, while I still have 3rd party hosting. I use a common SS insert that requires a larger tapped hole in the bracket. I use Loctite and stake them with done. I have been repairing these for many years now you can too.
Old Nov 16, 2017 | 05:50 AM
derekderek's Avatar
derekderek
I don't think GTR's repair is actual helicoil. Same basic idea. Either way, that insert or Helicoil is the only way to do the repair. Tapping bigger is not really any better than using smaller bolt with a nut behind it. The correct bolt with shoulder seats caliper correctly and stops it from moving around. So, not only do you need the correct thread, you need actual bolt, not a 7/16th fine thread from Home Depot.
Old Nov 16, 2017 | 09:23 AM
PainfullySlow's Avatar
PainfullySlow
I think that Gary is using a Time Sert which, in my opinion, is better than heli-coil.
Old Nov 16, 2017 | 09:45 AM
kenba's Avatar
kenba
From: PHOENIX AZ. WHAT A MAN WON"T SPEND TO GIVE HIS ASS A RIDE
Buy a new one & do it right. Its your brakes for Gods sake.
Old Nov 16, 2017 | 01:51 PM
KenSny's Avatar
KenSny
I agree REPLACE IT.
$40 is what, about a tank and a half of gas cost?
This is a system not to get cheap about.
Old Nov 16, 2017 | 06:05 PM
GTR1999's Avatar
GTR1999
I would not trust a coil in this application. The insert, if done correctly works fine. Incorrectly, well it will spin out when installing the caliper. I torqued the bolts to the bracket as shown and the repair was/is good.
Sometimes the original part is wanted over a new one, other times it isn't. What works best is what the owner wants and can do. Replacing it is $40 but requires pulling the axle out and that will lead to replacing the bearings and a lot more money. If a rebuild is needed then it is something to review. If a repair is needed, as in doing a caliper replacement then this will work- as long as it is done correctly.
Old Nov 21, 2017 | 04:38 PM
Tim McNamara
Navigator
Thank you all for the input...very much appreciated. And, It's not about the cost of the part. It's more about pulling out the TA being above my ability. I've been leaning towards just jumping in and giving it a shot but if I can't complete the job, how am I getting a car with no TA or wheel out of my garage and on to a flatbed to take to a shop.
Anyway, thanks again to everyone that replied.
Old Nov 22, 2017 | 06:23 AM
derekderek's Avatar
derekderek
https://www.corvetteforum.com/forums...onal-meet.html
Old Nov 22, 2017 | 07:20 AM
Tim McNamara
Navigator
Fair enough.
To Stripped caliper bolt hole
