While dash and center console removed
Old Nov 23, 2017 | 11:10 PM
tjmaniez's Avatar
tjmaniez
Default While dash and center console removed
I am completely redoing the stereo system in my 76 so in doing that I have removed the dash, gauge cluster, and the entire center console. While I have it all torn apart, does anyone have any recommendations for things I need/should replace. Basically everything is original. I am planning on replacing the light bulbs in the gauges but curious what the other restoration people think. I know it depends on the car but those with experience, I want to know your thoughts.
Old Nov 23, 2017 | 11:15 PM
A8skyhawk's Avatar
A8skyhawk
It would be convenient time to change out the dash wiring harness to a new one if you had any concerns about your old one. Also - now is a good time to check out the alignment of your driver side door as the hinge mounts can only be adjusted with the dash out.
Old Nov 23, 2017 | 11:20 PM
Raphiki's Avatar
Raphiki
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18
LED's
Old Nov 23, 2017 | 11:53 PM
ntfday's Avatar
ntfday
Veteran: Marine Corps
When I had my 76 apart I changed any of the bulbs that looked suspect and cleaned all the grounds. The po had installed a Kenwood stereo and I exchanged it for an Alpine CD unit and a six disc changer mounted behind the drivers seat. I put it there since I'm 5" 6 1/2" and the seat will never be all the way back. I dressed out the wire harness and used wire ties to keep things separated. I wouldn't change the wire harness unless it was hacked up and in poor shape. There are many DC-8's, 9's and 10's produced in the 60's and 70's still in the air and I very seriously doubt the wiring harnesses have been changed sinc they were manufactured and I worked many of them at the plant in Long Beach, Calif.
I split the speedometer and tach wiring into two harnesses and used molex plugs to make it easier if they come out again and they will as I plan on changing glass fuse block for a blade fuse block from any GM vehicle I can find in the boneyard.
If you want I'll start a thread with pictures of what I've done since I don't want to hijack your thread.
Old Nov 24, 2017 | 12:23 AM
7T1vette's Avatar
7T1vette
Check all operational components and mechanisms that have movement to be sure they are functional and have freedom of movement. This includes all vacuum servos and linkages in the HVAC system, dampers, doors, and seals too.
There is little to go wrong with the dash wiring harness, unless it has been hacked-up or had a fire/over-current problem. But all bulbs should be replaced. I've tried the LED thing: the Chinese bulbs don't fit properly in the sockets, several are bad out of the box, and they don't dim properly unless you add a PWM control unit in the circuit. New bulbs will last many years. You SHOULD repair any bulb sockets that fall apart when you remove the bulb. A little epoxy on the retaining prongs will keep that metal contact ring in place...permanently.
In general, you want to repair or upgrade everything in the dash area so you don't ever have to get in there again!
Old Nov 24, 2017 | 12:44 AM
henrikse's Avatar
henrikse
4x6 dash speakers? Check vacuum actuators for all hvac
Old Nov 24, 2017 | 04:59 AM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
Happy with your A/C? If not then now is the perfect time.ðŸ‘
David
Old Nov 24, 2017 | 10:55 AM
redrdstr72's Avatar
redrdstr72
If it was me and I had all that disassembly taking place, I'd at least think (hard) about installing Dynamat or one of the other heat and sound insulation materials. The area you have apart is a major source of heat transfer from the engine bay to the passenger compartment. I'd also look to seal any unused holes on the firewall, which allow heat, cold, water, etc to enter the passenger compartment.
Hope this helps.
Old Nov 24, 2017 | 07:17 PM
kanvasman's Avatar
kanvasman
Ditto the dynamat. Also, if there were any issues with your heater now is the time to check it all out such as vac lines or the core itself. Lots of stuff under there but it is really easy with the dash out.
Old Nov 24, 2017 | 11:02 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Hope this helps.
True Dat about heat shield/wrap......discolored heater core from seepage.
Old Nov 25, 2017 | 09:15 AM
jboweriii's Avatar
jboweriii
I spliced all my light bulb wiring with about 5 to 6". I can plug my light bulbs in and have enough room to as where they don't pop out on install
To While dash and center console removed
