1973 advice
Pictures and description sound great but I've been down that road before...
Is there anything particular to this model I need to look for?
https://www.corvetteforum.com/forums...-corvette.html
It explains a lot .
Have a look at the car and post some pics here , guys on here will help look at it for you .
I don't think there's anything specific to 73 cars that you need to be aware of.
The FIRST thing to look at is for any signs of rust.
Look through the windshield at the parts of the a-pillars that can seen.
Except for the windshield sealer the area should be quite smooth and painted black.
Then look in the door jambs in the area above the top hinge. This area can be quite sloppy but there shouldn't be any signs of rust or rust stains.
Try to get your head in the passenger's side foot well and look up behind the lower dash pad. You can see part of the cowl and the connection between the a-pillar and cowl from there. Again, look for rust and rust stains.
Take a look at the frame in the area just ahead of the rear wheels.
Look at the pocket the trailing arm mounts in, and also the area where the frame begins to kick-up over the rear wheel.
This are can be quite rusty.
Once you're confident that the car isn't rusty you can begin to look at the rest of it.
Remember, there's NO reason to buy a rusty car!
Good Luck!
Regards,
Alan
Good Luck!
Regards,
Alan
BTW..the video was really good. Basic, but plenty of meat on the bone.
This forum is an excellent place to get these types of questions answered. I've done 4 vettes of various years, over the years but the expertise here is exceptional. Sort of like building an engine...you know what to do but unless you do it every day it's best to talk to an expert.
Everything mentioned above is true for the '73. FYI! However, the front bumper area is completely different as I'm sure you are aware. When you check out the car take a good look in the nose area in front of the radiator. That's where you'll see the vacuum storage tank for the headlights, with all the vacuum hoses attached to it. It is part of the front bumper system. I would also look up under the front end at the area at the "impact system" and front frame area. Its quite different on the 73. You'll see the special bolt pictured below. If the square nut isn't in this location (and is farther back on the bolt, that means the car had a front end impact and the bolt did its job. However, once it's used up once it must be replaced, or the next front end impact will cause major damage to the front of the car. This is all part of the 5mph federally required impact laws from back n the day. Many owners and mechanics not familiar with the 73 impact system wouldn't know this and they would not have replaced it. Just something to take a look at on the car.
Hope this info is useful!
Tooch
Tooch
Is this bolt in the center or on each side...ie: the frame rails?
Thanks for all your help!
Good luck with your search and Happy Holidays!
Tooch
