I am Bubba
Old Dec 2, 2017 | 06:33 PM
Jack605's Avatar
Jack605
Default I am Bubba
Okay but it was just until my parts are ordered and get here, I ended up grinding a nail to take the slop out of the accelerator lever which is very nice now that the secondaries will open up. Still something not right she has a little hesitation when you get on the gas.
Jack
Old Dec 2, 2017 | 06:45 PM
A8skyhawk's Avatar
A8skyhawk
For what it’s worth I think I see that you have the 1969 early accelerator pedal assembly. I also had trouble with mine flexing - I ended up “upgrading” to the later single piece assembly that was less prone to bending.
http://www.zip-corvette.com/69l-76-a...pedal-rod.html
Old Dec 2, 2017 | 06:48 PM
Jack605's Avatar
Jack605
000003 is slightly early, Any issues with installation I like the look of the piece.
I am going to replace my rubber and the spring while I am at it.
Jack
Old Dec 2, 2017 | 07:01 PM
A8skyhawk's Avatar
A8skyhawk
It was easy to do - you also have to get the 69L pivot piece:
http://www.zip-corvette.com/69l-82-a...rod-pivot.html
When I did it years ago I fabbed up a cover to keep the rod from falling out of the tray. I’m now wondering if I did extra work and that perhaps it was designed to trap the rod against the floor - and mine is installed 180 out. Perhaps people will chime in with pictures of their 69L and up pedal assemblies.
Old Dec 2, 2017 | 07:11 PM
A8skyhawk's Avatar
A8skyhawk
Or.. Willcox to the rescue:
Old Dec 2, 2017 | 09:53 PM
croaker's Avatar
croaker
You can hardly tell!😜
Old Dec 3, 2017 | 12:02 PM
Vibguy's Avatar
Vibguy
My unsolicited advice.....be careful with bubbaness around throttles and brakes.
All it takes is one wide open stuck throttle event. It usually isn't a big deal until the steering locks when you turn off the key. Don't ask how I know
Signed,
Bubba the Vibguy
Old Dec 3, 2017 | 12:31 PM
Jack605's Avatar
Jack605
Signed,
Bubba the Vibguy
Understand and agree, parts are on order for a proper fix.
Jack.
Old Dec 3, 2017 | 01:38 PM
c3_dk's Avatar
c3_dk
Jack
I agree, 000003 must be defined as early
Old Dec 5, 2017 | 07:53 AM
pigfarmer's Avatar
pigfarmer
Not Bubba. You are a Field Engineer
Old Dec 5, 2017 | 11:28 PM
7T1vette's Avatar
7T1vette
Wait a minute!!! You actually MACHINED a part (be it a nail or whatever) to 'modify' an assembly until the correct part showed up. Bubba would NEVER do such a thing. Grabbing a rusty nail he found on the ground....maybe. But actually machining it to a proper size? No way.
I agree....Field Engineer...
Old Dec 6, 2017 | 09:03 AM
Bergerboy's Avatar
Bergerboy
The nut on the right needed to be snugged up to take the slop out of the joint.
I can't see the nail fix you employed in your photo.
I had this issue on my '69, and was able to simply tighten up the bolt/nut that clamps the pedal rod to the bracket loop.
This took the slop out of the joint, and gave 100% translation of the pedal travel, to the bracket/cable.
I actually discovered this early this Spring, and had been driving the car since I bought it last fall without the secondaries ever kicking in!!
Tightening up that joint, allowed the cable to fully pull the linkage to WOT, giving me a newly found "Hyper Drive"!!
Easiest, most impactful fix yet!
Old Dec 6, 2017 | 11:30 AM
Jack605's Avatar
Jack605
Tried that and it will not bind up the two bars, I also tried moving the two pieces closer and then tightening, no luck.
Parts should be here soon.
Jack
To I am Bubba
