Side pipe covers
Old Dec 10, 2017 | 07:33 PM
Joe79Vette's Avatar
Joe79Vette
Default Side pipe covers
I bought a set of used reproduction Oem side pipes covers and was curious if the holes are predrilled for the rocker holes. The holes don't seem to match up with my 72. A couple do but not all of them. What is good way to repair these holes that don't match up.
Joey
Old Dec 11, 2017 | 08:31 AM
Alan 71's Avatar
Alan 71
Hi Joey,
I would consider using the existing mounting holes in the insulators and drill the appropriate/needed holes in the rocker channel to receive self tapping screws.
I'm not sure changing the screws spacing is a good idea.
There is a reinforced area in the fiberglass insulator at each point the original holes penetrate it.
Regards,
Alan
Old Dec 11, 2017 | 08:40 AM
Joe79Vette's Avatar
Joe79Vette
Thanks Alan. That was a thought too. I think that will be my plan.
Thanks again
Joey
Old Dec 11, 2017 | 12:44 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
They should have matched up... not sure why. We just installed a set on a 69 in the shop. You do have to remove some of the front fender lower fiberglass and the rear. Use this pdf as a guide. http://repairs.willcoxcorvette.com/w...tion-guide.pdf
Willcox
Old Dec 11, 2017 | 01:31 PM
Kid Vette's Avatar
Kid Vette
He's installing on a 72. The spacing changed between 69 and 72.
Old Dec 11, 2017 | 02:45 PM
Joe79Vette's Avatar
Joe79Vette
I was wondering if this happened? I was using the diagram from Willcox as well and the holes just seem wrong.
Thanks,
Joey
Old Dec 11, 2017 | 02:52 PM
Alan 71's Avatar
Alan 71
Hi,
I believe the location of the blind nuts in the rocker channel changed for the 70 model year when the 1 piece rocker trim was introduced.
Regards,
Alan
Old Dec 11, 2017 | 03:13 PM
0Willcox Corvette
Former Vendor
Originally Posted by Alan 71
Hi,
Regards,
Alan
You guys are correct, I missed the fact that the car was a 72. The holes are different.
Willcox
To Side pipe covers
