Four Wheel Alignment Question
Old Feb 15, 2018 | 01:14 PM
gr8t73's Avatar
gr8t73
Alignment completed and drove the car home from the shop about eight miles away. Only a slight improvement in return to center. I am considering replacing the power steering cylinder as this is the only thing left to try. Although the current cylinder was installed new when I restored the car it is about 14 years old. No leaks but when I did the centering adjustment it didn't seem to be very sensitive to changes in the adjustment. I remember my 77 would swing with a fair amount of force when I made adjustments in the centering nut. Just not sure how much a weak power steering cylinder would effect the return to center. Any thoughts would be appreciated. BTW current alignment readings are:
Caster: +4.22 LH +4.24 RH
Camber: -.04 LH -.04 RH
Toe: +1/32" LH +1/32"RH
Old Feb 15, 2018 | 06:23 PM
ignatz's Avatar
ignatz
My thought: just from common sense, why would the power steering hydraulic cylinder, which is being used to turn the wheels, also be expected to provide a restoring force? The adjustment is there to balance the pressure in either direction.
Old Feb 15, 2018 | 06:54 PM
CanadaGrant's Avatar
CanadaGrant
I understand Gary rebuilt your steering box but with that much caster you should have really good return-to-center on the steering. I was wondering if the box is just a little on the tight side preventing this? It only takes a quarter turn off on the adjuster to run into a problem. You might mark the position of the adjuster on the box then back the adjuster out a quarter turn or so and see if it improves. If it doesn't work you can set it back to his settings and it's also free and easy to try. With a fresh alignment and that much caster you shouldn't be having this problem.
Old Feb 16, 2018 | 11:44 AM
gr8t73's Avatar
gr8t73
That's a very good point Canada. I will try this adjustment this weekend. Like you say costs nothing.
Old Feb 16, 2018 | 12:43 PM
CanadaGrant
I had this happen before with a new box and threw quite a bit of money at it on pretty well new everything before I finally figured it out and turned my attention back to the box. I backed the adjuster out just a bit and that cured it. Kind of a weird feeling when you let go of the wheel and it stays in a turn....
Old Feb 20, 2018 | 11:18 AM
gr8t73's Avatar
gr8t73
I backed off the adjuster one full turn which was too much and gave me too much slack in the steering although it did help with the return to center but not as much as I had hoped. Ended up backing off only a half turn return to center is better but still not what it should be. I am at a loss at this point as to what to try next. As always any thoughts on what I should try or check are appreciated.
