Inside/outside
Old Dec 19, 2017 | 02:28 AM
Neil Kuslansky's Avatar
Neil Kuslansky
2nd Gear
Default Inside/outside
Just bought a 79. My question is, is it the inner or outer rear light that is the turn signal, right now when i use my signals the left one activates the outer light. The right one activates the inner. Im sure its just an incorrect bulb placement, but not sure which one is wrong.
thanks for any help. I'm sure I'll have more questions. I never leave well enough alone.
Old Dec 19, 2017 | 07:02 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Inner rears are back up lights unless a previous owner did a bubble light conversion. Sounds like the lamp holders on the right side may have been swapped.
Old Dec 19, 2017 | 12:26 PM
Neil Kuslansky
2nd Gear
All four lenses are fully red.
Old Dec 19, 2017 | 12:35 PM
7T1vette's Avatar
7T1vette
As mentioned, the only 4-red-tail lamp C3 model was the 1968 which also had back-up lamps installed in the lower rear panel. Many later-C3 owners chose to convert their rides to 4-red-tail lamps...but many didn't do a good job of wiring.
The OUTER lamps were the turn signals; the inner lamps were tail lamps and back-up lamps.
Old Dec 20, 2017 | 08:17 AM
Easy Mike's Avatar
Easy Mike
Originally Posted by Neil Kuslansky
...All four lenses are fully red...
Sound like an aftermarket bubble light conversion. Something like this?
Old Dec 22, 2017 | 01:47 PM
SwampeastMike's Avatar
SwampeastMike
In 1979 the inners house backup lights only. The red around the white center is a reflector.
The outers are the brake/turn/tail lights.
Old Dec 22, 2017 | 01:51 PM
Aerovette's Avatar
Aerovette
Sounds like the bulb holders are in the wrong lenses on one side.
Old Dec 24, 2017 | 05:50 PM
lvmyvt76's Avatar
lvmyvt76
doesn't have to be an aftermarket conversion, could be just 4 brake light lenses and new sockets for the inners, and wrong bulbs or wiring done wrong or lost grounding etc.
Old Dec 24, 2017 | 06:51 PM
Peterbuilt's Avatar
Peterbuilt
Outside sockets have 3 wires.
Left side:
Brown = tail
Yellow = Directionals & Stop
Black - Ground
Right side;
Brown = tail
Dark Green = directional & Stop
Black - Ground
Inside sockets have 2 wires and were for back up only
Brown = back up 12 volts
Black = Ground
Schematic:
https://docs.google.com/viewer?a=v&p...TYyNWViMWY1NzY
Old Dec 24, 2017 | 08:25 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
I put the bubble light kit on my 81.
Iiked them on my old 68.
Cut and soldier the wires and put back up
Lights on the frame each side of license plate.
To Inside/outside
