Engine swap
Old Dec 28, 2017 | 02:30 PM
scondon's Avatar
scondon
Default Engine swap
I have a question. My 75 coupe has a late 80,s truck engine in it. I just purchased a 77 coupe donor car that has the original engine in it. If I take the truck engine out and put in the 77 coupe engine will I be in the ball park of period right engine.
Old Dec 28, 2017 | 02:48 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Define "ballpark." The 77 engine will be two years younger than your car. Visibly, you could install 75 valve covers and air cleaner and folks may not be able to tell the difference. Keep in mind 75 engines were Chevy orange; 77s were corporate blue.
Old Dec 28, 2017 | 03:09 PM
dmaxx3500's Avatar
dmaxx3500
truck/car eng?,mostly the same thing,,why/what are you doing this?
Old Dec 28, 2017 | 03:36 PM
derekderek's Avatar
derekderek
What year is the Truck Engine? It could actually be superior to the 77 Corvette engine. Trucks did not have the emissions hassles Passenger cars had. That's why in 76, the fastest thing out there was that Dodge little red express truck with a 360 in it. It would smoke any other production car made that year.
Old Dec 29, 2017 | 06:04 PM
Gold Dragon's Avatar
Gold Dragon
Unless the 77 donor motor has more HP, I would stick with what you have. Seems like Alot of work, and really would not add much value. In my opinion. Get some use out of it and enjoy it.
Old Dec 29, 2017 | 07:26 PM
Cavu2u's Avatar
Cavu2u
The '76 C-10 engine I received for my '73 had 4-BOLT MAIN bearing caps, and I made a 383 out of it too.
Steve
Old Dec 29, 2017 | 07:58 PM
scondon's Avatar
scondon
Steve
Nice. Guess I will rethink swapping engines But now I have another 350 to build or swap for something else.
Old Dec 30, 2017 | 08:15 AM
pigfarmer's Avatar
pigfarmer
I think a Chevy V-8 with a carb & distributor is the 'right' engine for that car.
Old Dec 31, 2017 | 09:24 AM
joewill's Avatar
joewill
yes you will be in the ball park, but in general, to be considered to be a correctly dated engine, then the casting dates of the block/heads/intake/exhaust needs to be within 1 week to 2 months of the car's build date..
with a max of a 6 month spread in order to get judging points via judging organizations.
To Engine swap
