stripped!!!
Old Jan 9, 2018 | 07:02 PM
jack mac's Avatar
jack mac
Default stripped!!!
well..the 77 is getting close..soo I was check fitting the new ..sill plates..and what do ya know...all the sill trim plate screw holes are...stripped..what is the...fix??...please dont say...pull the body back off..n fill n drill.....nooooo
Old Jan 9, 2018 | 07:06 PM
flyeri's Avatar
flyeri
Rivnuts, Google it. I had to do all eight of mine. You will need a tool but it will not be the last time you use them.
Old Jan 9, 2018 | 07:21 PM
jack mac's Avatar
jack mac
OK...thats what i thot...have the.."kit"..already..thanx much !!
Old Jan 9, 2018 | 07:42 PM
540 vette's Avatar
540 vette
Bend a cotter pin and fit it into the hole and then put the screw in. The cotter pin will make up the space.
Old Jan 9, 2018 | 07:44 PM
jack mac's Avatar
jack mac
yeah that worked on a few...hackers really messed em up,,,thanx
revitup's Avatar
revitup
Bent piece of safety wire or a paper clip in the hole first, under the sill plate.
Old Jan 9, 2018 | 09:32 PM
ENCSDOUG's Avatar
ENCSDOUG
I used small red Sheetrock anchors. Worked great.
Old Jan 9, 2018 | 09:35 PM
jack mac's Avatar
jack mac
yeah!!..i tried a ..blue one...didnt have ..red's....will do...thanx much....really!
Old Jan 10, 2018 | 03:27 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
I HATE Riv-Nuts....I would rather TIG or MIG WELD for Originality......BUT........
If you use several drill (bits) to GRADUALLY IN STEPS drill a "TIGHT" hole for the Riv-Nut to be forced into...........the Riv-Nut will "grab well/securely when riveted....and should NOT "spin/get loose" UNLESS you try really hard.
Old Jan 10, 2018 | 05:01 AM
Haggisbash's Avatar
Haggisbash
I used stainless steel rivnuts but instead of compressing them with the tool I epoxy glued them into the holes, so far so good,have been in place around four years now.
Old Jan 10, 2018 | 06:45 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...I used...Sheetrock anchors. Worked great...
Same here. Easy fix.
Old Jan 10, 2018 | 11:01 AM
jack mac's Avatar
jack mac
yes..im going with the...anchors
Old Jan 10, 2018 | 01:14 PM
doorgunner's Avatar
doorgunner
The good news is...if the anchors ever fail, you have the "repair kit" in your tool box..........
OR..........................
Old Jan 10, 2018 | 01:44 PM
jack mac's Avatar
jack mac
Default fix
yes the..red ones..worked perfect...great idea to try first..for sure
Old Jan 10, 2018 | 08:58 PM
BLUE1972's Avatar
BLUE1972
used a metric screw, they are slightly larger - fit well.
When I re-do the interior, I will make repairs..
Old Jan 11, 2018 | 08:52 AM
Tampa Jerry's Avatar
Tampa Jerry
Default Zip tie
I use a piece of a zip tie in the hole. The plastic will give enough to make it tight. Two will work for a large hole. Jerry
Old Jan 11, 2018 | 09:55 AM
jack mac's Avatar
jack mac
Thanx...the .."red"..sheetrock inserts were..perfect.
To stripped!!!
