Winter Work
Old Jan 10, 2018 | 01:00 PM
PHILB1's Avatar
PHILB1
Default Winter Work
So its January, time to get to some of the projects while the snow falls here in the northeast. looking to go through my cooling system, and I am going to remove the hood. Any suggestions on storing the hood. I will be covering in a couple of moving blankets but what considerations do I need to take into account when laying flat or standing on end. Are they any special considerations because its fiberglass?
Old Jan 10, 2018 | 01:49 PM
PHIL 68's Avatar
PHIL 68
I would not stand it up in case you damage the corners I simply got 2 2 by 4s placed 1 across rear and 1 across front tied ropes around the ends and hung them up Phil
Old Jan 10, 2018 | 01:57 PM
Alan 71's Avatar
Alan 71
Hi Phil,
I agree with Phil that the rear corners and center front are pretty easy to damage.
Even if you're going to lay it flat...
You might consider buying a length of clear plastic tubing at the home store.
Cut it in 3 pieces and slit each piece lengthwise.
Slip each piece in place and secure it with painter's tape in a couple of places if it seems like it wants to come off.
This protects both the paint and fiberglass.
Regards,
Alan
Old Jan 10, 2018 | 04:31 PM
bazza77's Avatar
bazza77
I have a long hood hanging in my shed , all I did was get some sturdy thin rope and tie it across from two beams , up against a wall , put the bolts with washers back in the hinge mount holes but leave a few threads out and hook the rope up between the washers and the glass. Nice and neat , up high and out of the way.
Old Jan 11, 2018 | 05:20 AM
terrys6t8roadster's Avatar
terrys6t8roadster
The walls in my shop are wood. I just pounded in nails at the appropriate height to the latch pin holes and hang. T
Old Jan 11, 2018 | 11:45 AM
540 vette's Avatar
540 vette
I have some roll bar padding and slit it and put it on the edge and stand the hood in the garage with a soft blanket over it
Old Jan 13, 2018 | 08:57 AM
lvmyvt76's Avatar
lvmyvt76
I had some carpet padding from changing out to new carpet, rolled it up and sat the front pointed side on that, leaned against the wall away from traffic etc. No problems, sent the hood off to be painted the correct color to go on the hood.
Old Jan 13, 2018 | 09:21 AM
Mooser's Avatar
Mooser
Garage is pretty small so it's usually in the house
I put a folded (to make it thicker) moving blanket on the floor against the wall and stand the hood up on it's side against the wall with another folded blanket over the other side where it touches the wall.
M
Old Jan 15, 2018 | 08:10 AM
Hayes69's Avatar
Hayes69
I put mine on a couple saw horses with moving blankets on top. Worked great.
Old Mar 19, 2018 | 08:51 PM
PHILB1's Avatar
PHILB1
Thanks everybody great advice, wrapped it up in moving blankets. Stood against the back wall out of the way.
To Winter Work
