where?
Old Jan 13, 2018 | 07:54 PM
jack mac's Avatar
jack mac
Default where?
A ..New Arrival..71 Greenwood..need ..regrooving..has a 72 frame,69 diff,78 nose n tail.74 A body 3502bbl 140 hp..and 78.."big shaft" trans...the door panels are 78...the 71 console was ..all wrecked...where was the ..pdl switch for 71?..78 is on the ..doors...someone have an image ...maybe?
Old Jan 13, 2018 | 08:41 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
what is a PDL switch?
did you remove all the dash and cluster?
a 350 2 barrel at 140hp?
how did that happen?
Old Jan 13, 2018 | 08:52 PM
jack mac's Avatar
jack mac
a 350 2 barrel at 145hp?
yeah..that would be...Power Door Lock...thanx
man..did ya see the...picture...there was..nothing..to remove..!
I know 71 PW switches are on the E-brake cover...a 74 impala with a 350 /2 has 145 hp
thats where the engine came from
Old Jan 13, 2018 | 08:57 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
ok, power locks, just rebuilt my actuators.
they were gummed up.
my switch is on the doors.
if i remember all the wires go to passenger door there first.
as far as engine, well a lot can be done to the small block 350.
Old Jan 13, 2018 | 09:18 PM
Mooser's Avatar
Mooser
I do not believe 71 ever came with power door locks. Maybe around 78+
M
Old Jan 14, 2018 | 05:54 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Mooser
...I do not believe 71 ever came with power door locks. Maybe around 78...
Correct. No power locks until 78.
Old Jan 14, 2018 | 07:37 AM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
I want to thank you for posting this and thank you for showing some pictures of the car. It highlights what I am calling "early restomod" work but we may have just called it modified or custom back in the day. It is or was one person's vision of what the car could be and or another example of what I have run into which is I just needs parts and if it fits and works that is good enough for me.
Whatever the case may be I appreciate you showing the differences and good luck with this one, should be fun.
Best regards,
David Howard
Old Jan 14, 2018 | 08:48 AM
gbvette62's Avatar
gbvette62
As was said above, 71's were not available with power door locks. They first became available in 78, and the switches were on the door panels.
From the pictures, it appears your power door lock switches may still be on the door panels. The power lock switch is a square chrome toggle switch, that says "LOCK" on the bezel. The manual lock *****, are the chrome ***** inside the arm rest.
Old Jan 14, 2018 | 06:42 PM
72 Project's Avatar
72 Project
It appears to be a 78 Silver Anniversary interior. Are the wires run for the door locks?
Old Jan 14, 2018 | 06:57 PM
jack mac's Avatar
jack mac
no ..'cause it is a...71???
Old Jan 14, 2018 | 09:37 PM
Mooser's Avatar
Mooser
Does it have PDL in the doors just not hooked up? Do you want PDL?
If the car had power windows then there is a rubber conduit between the car and the door and the wires for the PW run through there. If that isn't there then you'd have to drill holes in the door and jamb and then get some rubber conduit to seal them etc etc etc.
You can add PDL to early doors fairly easily, sneak the wires through the exiting conduit and wire them into the switches that look like they are on your door panels already
Here's a picture of a power lock actuator added to a 72 door linkage
The pivot arm that it's attached to is welded on top of the original bellcrank but people have done the same idea with large washers
I wired it with remotes so there are no switched inside the car for the doors
HIH
M
If you were going to add PDL you might want to check the 78 panels you have to know there is some room down there, otherwise look at where they put the actuators on the 78+ years (vertical as I recall)
Old Jan 14, 2018 | 09:45 PM
jack mac's Avatar
jack mac
HIH
M
turns out this 71.has 78 doors on it....i just didnt realize that it was also the first year for...PDL
To where?
