Willforce71 71 LS5 Resto??
I am really torn with this header thing. I love the look and sound they have but I think something is off with these old ones I have. From what I have read this isn't a new issue. It doesn't make sense to me why after more than 50 years these C3 big block cars have been around that you can't get a set of side pipe headers that don't interference problems??
I looked at long tube BB headers and then decided to go with a set of Sanderson short tube BB headers.
According to Sanderson they fit with no clearance issues and I won't have to dent a tube for clearance with the Borgenson steering box.
They come with 1 7/8" primary tubes of 16ga mild steel, 3/8" flanges, 3" collectors, they are aluminum ceramic coated inside and out and will eliminate ground to collector clearance issues as well.
My research showed that short tube headers will produce more tq/hp below 3500 rpm, about equal 3500 to around 5500 and that the long tube headers only make more hp above 5500 rpm.
Thanks for the info, I hadn't even considered Sanderson. How much better do they flow than the stock BB cast manifolds? I have just about given up on the side pipes at this point so the Sanderson or the stock manifolds are looking like the path I will take.
I would run a good header system any time over a stock exhaust manifold any time.
Just my opinion.
Been a little slow in getting some new pictures uploaded lately but, here are some to catch up to where I am today. Finished assembling the rear Van Steel Suspension and mounted the wheels.
I will be setting the chassis aside for a while and focus on the body.
I am also going to get all the gaps and seams perfected while the body is back on the frame. I will then pull the body back off to clean up the underside and do most of the blocking and priming. At least that's the plan.
https://www.corvetteforum.com/forums...-stripped.html
Enough about me here is the status as of today. I was able to get the bodywork finished up and Primed with both Epoxy primer and Poly. Block sanding of most of the panels is coming along well. I decided to pull the body back off the chassis to make cleaning and prepping the bottom and wheel wells easier. I had to make a new Dolly as well because the original was sacrificed in the move. The new one is taller and allows better access to the bottom areas.
I will be working hard over the next couple months to prep the body and all the painted bolt-ons for paint over the Thanksgiving Holiday. More to come.
New Body Dolly allows a lot better access to the bottom of the car.
Its essentially three ropes stretched across the garage just under the doors. I build end walls out of 2x3 and attached them to the ropes to hold them up. Masking plastic finished things up. I used a 24" fan blowing in and 2 20" box fans to blow out. I added a third fan blowing out to regulate the pressure. So with the big fan on high and the two 20's on high I can use the 3rd out fan on low and add speed as the filters start to clog up.
Everything worked well and I should get the body done Thanksgiving day?
Ropes and end wall frames
Input Fan
As you can see I was able to get a nice positive pressure inside the booth. This keeps the dirt on the outside.
Output fans
As you can see I decided to go with Black! I deliberated about this for a long time and felt that doing what I like is what this car is all about.
Body Lift went very smooth. I have done it now several times so practice makes perfect.
Headlights and hood went ok as well. Don't worry, I did have tape around all the edges.
New wiring harnesses and Vintage Air install has been slow. Seams like one step forward two steps back but I am slowly getting it together.
The hoses are definitely a tight fit. Vintage Air should consider a molded plenum similar to the factory one for the center vents. It is easier to do with the dash pad and windshield out of the car though.
I have made a lot of progress assembling this puzzle. I have a few little details left to install but am mostly complete. All systems are working great except the wiper system. I will start troubleshooting that in the next week or two but I am not too worried about it because I can't see this thing in the rain any time soon. A/C works great which is very important here in Florida.
I just shipped the numbers matching block and crank to Mark Jones at VortecPro for him to do his magic on. Can't wait to swap it in and finish this thing up.
Almost time to find a new project!
