coolant temp gauge not moving
Old Jan 31, 2018 | 06:51 PM
pleasants9's Avatar
pleasants9
Default coolant temp gauge not moving
Recently my temp gauge of the coolant has stopped moving. The oil temp gauge will go up but not coolant. What can I do to test if it is the gauge or the sensor that has gone bad?
Old Jan 31, 2018 | 09:08 PM
Tecdiverfl's Avatar
Tecdiverfl
on the front left side of the motor in the head is the sensor. First thing check the connector mine has popped off the sensor a few times. You can also ground the wire out and see if the gauge moves. If it does sensor is bad
Old Jan 31, 2018 | 09:52 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
The connector on my sensor was making poor contact too. Slightly crimping the connector made it snap onto the sensor tightly.....no more problems
Old Jan 31, 2018 | 11:42 PM
7T1vette's Avatar
7T1vette
With ignition ON (engine not running...nor does it need to be warmed up), remove sending wire from temp sender; needle on temp gauge should go full-scale to the right. Now touch that connector terminal to electrical ground (frame or any metal that has solid connection to ground, alternator case, etc); the needle should go to 0 (full-scale left).
If something close to that happens, the wiring and gauge are fine; the sending unit is 'toast'.
To coolant temp gauge not moving
