3 point conversion ....
Old Feb 3, 2018 | 07:08 PM
The Phantom's Avatar
The Phantom
Default 3 point conversion ....
So I'm looking ahead to seat belts, my thoughts are to go away from the stock 71 set up but I'm thinking a full harness set up might be a bit much. I've come across this 3 point conversion set up at Corvette Mods,
https://www.corvettemods.com/C3-Corv...t_p_10933.html
Just wondering if anyone has ever installed this set up and what they think?
Dave
Old Feb 3, 2018 | 07:31 PM
Mooser's Avatar
Mooser
Have you considered the F-body belt conversion?
https://www.corvetteforum.com/forums...post1592362003
I've got a set of belts if you're interested, Grey but could be dyed
M
Old Feb 3, 2018 | 07:39 PM
The Phantom
M
Actually I saw your post, it made me wonder what other options were out there.
I'll keep it in mind.
Dave
Old Feb 3, 2018 | 09:49 PM
bazza77's Avatar
bazza77
Do you have the captured nut above your head on the B pillar ? for the top mount point ?
Old Feb 3, 2018 | 10:34 PM
The Phantom
I'm going to say no.
Dave
Old Feb 5, 2018 | 04:25 PM
bazza77's Avatar
bazza77
Dave
do you want to or need to put two in ?
I put them on my 69 which didn't have any ,if your interested I could show some pics
Old Feb 5, 2018 | 04:45 PM
The Phantom
That Sir would be great, everything is better with PICS!
Dave
Old Feb 5, 2018 | 05:48 PM
vettebuyer6369's Avatar
vettebuyer6369
Dave
Have you done a search for threads on Corvette Mods in the Transaction Feedback section?
Old Feb 5, 2018 | 06:01 PM
The Phantom
There were questions on fitment but no installations.
https://www.corvettemods.com/C3-Corv...933.html#tab-4
Dave
Old Feb 5, 2018 | 06:31 PM
bazza77's Avatar
bazza77
I wouldn't buy from them, mainly as I'm too far away in case it goes bad
here's a pic of me holding up the steel that's drilled and tapped next to where I have already put one in ,
you can see the shadow left over from the trim mounting part I had to cut away to get to that spot . I got to that spot by using a panel from a 74 that had the top mount and just centre punched a spot in the middle of the hole of panel , easy.
to get the steel up there I used some plastic trim stuff and taped it to the steel and manoeuvred it around , its tight ,but I got it there . I did however use too much tape which made it hard to break it away after.
that steel is about 1/2 inch thick and with a fine thread ,is about the same amount as the original captured nut . Kit comes with two small rivets to hold it there while its not finished .
My kit is made from new parts and is engineered approved down here so at about 300 I feel its worth it over just lap belts .
Old Feb 6, 2018 | 12:04 AM
theandies's Avatar
theandies
Here is the GEN 4 Camaro/Firebird setup to go through the seat. I did this mod to my '71 years ago but have not taken them through the seat yet as my seats are shot and need to be rebuilt or I'll do a seat swap to something more comfortable.
Old Feb 6, 2018 | 02:54 AM
vettebuyer6369
Dave
Not the product, the company.
Not in C3, in Transaction Feedback.
To 3 point conversion ....
