Dash Harness routing
Old Feb 6, 2018 | 10:18 AM
Tecdiverfl's Avatar
Tecdiverfl
Default Dash Harness routing
Looking for a picture of the correct routing for a harness on the drive side. I need the routing of the harness on the left side of the steering column in regards to the 2 bars that support the column and where the wires for the dash lights should be run
Marty
Old Feb 6, 2018 | 10:46 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Model year? The AIM is possibly the best source for an answer. Actual routing could vary by model year.
Old Feb 6, 2018 | 10:49 AM
Tecdiverfl's Avatar
Tecdiverfl
Sorry 1970
Old Feb 6, 2018 | 11:28 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Old Feb 6, 2018 | 11:35 AM
BBCorv70's Avatar
BBCorv70
Originally Posted by Tecdiverfl
Sorry 1970
Beware, the early 70 had the harness routed as it is in 69, under the tach and speedo. Later that year it was moved to over the tach and speedo.
Old Feb 6, 2018 | 12:41 PM
Tecdiverfl's Avatar
Tecdiverfl
If memory serves my car has a late March or April build date as I know the motor was dated March 70
Old Feb 6, 2018 | 01:07 PM
0Willcox Corvette
Former Vendor
Easy to tell too... just look at the clips on the speedo tach cluster.
Willcox
Old Feb 6, 2018 | 01:23 PM
Tecdiverfl's Avatar
Tecdiverfl
Willcox you guys are the best as usual
Old Feb 6, 2018 | 01:27 PM
Alan 71's Avatar
Alan 71
Hi T,
Here's the routing with the harness OVER the speedometer and tachometer.
Note the clips Willcox indicates.
Note the harness dips down slightly between the 2 gauge bezels because of the wiring headed to the steering column.
Regards,
Alan
Coming up from the fuse panel.
Dipping down for the center gauge cluster, radio, and shifter console connections.
Old Feb 6, 2018 | 01:37 PM
Tecdiverfl's Avatar
Tecdiverfl
I need to look when I get home
Old Feb 6, 2018 | 03:14 PM
BBCorv70's Avatar
BBCorv70
My 70 was built March 3, harness went under the tach and speedo. I don't think there was enough slack to route it over the tach and speedo as I would have preferred.
Old Feb 6, 2018 | 07:55 PM
Tecdiverfl's Avatar
Tecdiverfl
I am assuming when mine was restored they put a late 70 harness in an early 70. I can route over but have tabs for a lower
To Dash Harness routing
