Does this steering pump pulley fit?
Old Feb 13, 2018 | 04:41 PM
stingraymaniac's Avatar
stingraymaniac
Default Does this steering pump pulley fit?
https://www.summitracing.com/parts/bsp-86420
It doesn't look to do it but there are some reviews from Corvette owner's
Anyone here that has it ?
I'm looking for a pulley that fits the standard pump
Old Feb 13, 2018 | 07:17 PM
Mooser's Avatar
Mooser
Although that description say either keyway or press-on, if you check on billet specialties site it'll be for a long pump, press-on shaft NOT a keyed shaft pump.
(just went through a tone of pulley info looking to replace my double with a single pulley)
86120 is the single keyed shaft pulley, can't tell you if it lines up on a SB
M
Old Feb 14, 2018 | 05:49 PM
stingraymaniac
Seems to be hard to find a pulley for a short pump and without ac, the most ones are to the ones with ac and they doesn't look the same..
Maybe I should get it powdercoated in aluminum color instead
Old Feb 14, 2018 | 05:55 PM
stingraymaniac
The one I have look like this, only painted here i would like it to have a more polished look
Old Feb 14, 2018 | 09:22 PM
Mooser's Avatar
Mooser
If you go to Marchs site you can see what they offer for offset dimensions on their various pulleys
http://marchperformance.com/accessor...g-pulleys.html
but without changing the WP pulley and maybe brackets you may find it hard to match up.
Speedway also sells a single groove, 5/8 keyed short water pump pulley, part number 91032916, check the dimensions for the offset
I did find a deep single groove PS pulley (steel) that allowed me to change from the cast 2 groove to a single but that's not likely what you're after
HIH
M
Old Feb 14, 2018 | 09:31 PM
carriljc's Avatar
carriljc
Just looked up the deep groove pulley part number from my notes on my power steering pump:
Power steering pulley (deep)(GM)
3834720
This is a key slotted pulley. As cheap as 60 bucks on ebay as of the date of this post.
Does your pump shaft have a key/keyway?
You can see it, as installed, here:
Old Feb 14, 2018 | 09:39 PM
Mooser's Avatar
Mooser
3834720
I think that's what he already has and he's looking to change it to something better looking. I could be taking it totally wrong though in which case the info I gave is more useless than normal
M
Old Feb 14, 2018 | 09:48 PM
carriljc's Avatar
carriljc
Yeah, I'm a bit confused ....but as long as I did the research... it looks like the 1974 SBC Corvette PS Pulley was 3770509 per this reference:
http://gmpartswiki.com/getpage?pageid=39417
Last edited by carriljc; Feb 15, 2018 at 11:10 AM. Reason: corrected typed-in part number AND replaced fuzzy image
Old Feb 15, 2018 | 01:44 AM
stingraymaniac
I don't know if its a 74 pump though, the car had a 66 327 in it when I got it years ago
Old Feb 16, 2018 | 09:43 AM
jimvette999's Avatar
jimvette999
You could polish yours with sanding discs to a smooth finish then apply primer and paint or all in one primer paint. It's not a bad looking three spoke design IMO.
These 3M sanding roloc discs make short work of it.
Brake cleaner and de-lint prior to shooting.
This is good>>>
This is not>>>
Old Feb 16, 2018 | 01:42 PM
stingraymaniac
Yeah I'm gonna take it off and sand it down so it gets a smooth finish, and then powdercoat it alulook
To Does this steering pump pulley fit?
