Hi beam headlight problem
Old Feb 18, 2018 | 01:50 AM
BJN's Avatar
BJN
7th Gear
Default Hi beam headlight problem
I have a 1980 corvette and been having a problem of my headlights flickering or going out completely when my high beams are on for a while. wondering if I need to replace the light switch or look elsewhere.
Old Feb 18, 2018 | 04:04 AM
sug's Avatar
sug
2020 Corvette of the Year Finalist (stock)
C3 of Year Winner (stock) 2019
I would check all the earth connections are tight.
Old Feb 18, 2018 | 08:53 AM
JimT's Avatar
JimT
I had the same issue. Pull the headlight shrouds off, remove the bulbs, and check the connections. This area collects a lot of dirt and grime. Spray connector cleaner into the connectors and apply a small amount of dielectric grease onto the bulb prongs.
Old Feb 18, 2018 | 12:50 PM
BJN's Avatar
BJN
7th Gear
Default Thanks
. Thanks didn’t think of checking those. Will give it a try.
Old Feb 19, 2018 | 12:24 PM
Bergerboy's Avatar
Bergerboy
Not sure about your '80, but on my '69 I had this issue after installing an aftermarket replacement H/L switch.
Turned out to be a cheap thermo protector internal to the switch. The regular H/L's would work fine, but hitting the brights would increase the current draw, and after a few seconds, the thermo would cause ALL the lights to flicker and - eventually - go out until it was cooled down again.
Tried 3 new switches before deciding to rebuild the original switch, by just replacing the dimmer coil unit (the original failure I had), and this did the trick.
Old Feb 19, 2018 | 07:51 PM
BJN's Avatar
BJN
7th Gear
Thanks for the info. Was suspecting the light switch. I knew that there was a thermal safety in the switch. I don’t know if it is the original switch. I’m going to try cleaning the connectors for the headlamps first. If that doesn’t work I will replace the switch. I have already checked the ground connections.
Old Feb 20, 2018 | 06:45 PM
Bikespace's Avatar
Bikespace
I know this one. It is a light switch, but probably not the one you think. I had this happen on my '80.
Maybe you can do this with the seat out and laying on your back (you might have to anyway), but take the dash assembly out. The only tricky bit is the speedometer cable. Then you can easily access the headlight switch (the one with the thermal breaker). If it is melted, and/or doesn't show correct voltage with a multimeter, there's your culprit.
However, I bet the high-low beam switch has failed. It is mounted on top of your steering column, and is not trivial to replace. It's a lot easier with the dash cluster removed. This is a $15- part on a C3, so a lot cheaper than the other option. Make sure you adjust it correctly.
Good luck!
Old Feb 20, 2018 | 08:53 PM
BJN's Avatar
BJN
7th Gear
Good luck!
Thanks for the info. I will put that on my list of things to trouble shoot! Haven’t had a chance to work on it yet. Hoping to be able to get to it this weekend.
Old Feb 20, 2018 | 10:23 PM
Richard454's Avatar
Richard454
Heres a way to check-
Headlight switch or bad connection at the lights.
When the lights start to flicker-disconnect one highbeam ( passenger side will work best)
See if that solves your problem.
If it does- look at the connections- grounds as others have stated.
If not- then you have to learn some acrobatics and remove the light switch.
Richard
To Hi beam headlight problem
