Another Undercoating Question.
Old Feb 20, 2018 | 08:18 AM
Cavu2u's Avatar
Cavu2u
Default Another Undercoating Question.
General Ike's thread answered one question I had. Thank you Sir!
Now, what chemical removes it?
Since the previous owner of this '73 put oversized tires on (), the scrapping eliminated the edge that attaches to the Splash Shields. To rebuild that bottom wheel well edge properly, the undercoating has to be removed. Does anyone here have experience on what works best on this?
Thanks much.
Steve
Old Feb 20, 2018 | 08:29 AM
Mr D.'s Avatar
Mr D.
Use the following steps
1) Heat Gun
2) Scrapper
3) Paint stripper
4) Scrapper
5) Lots of rags
6) Clean up with lacquer thinner
Optional Item ---> Shower cap to keep the undercoating out of your hair
Old Feb 20, 2018 | 08:57 AM
Alan 71's Avatar
Alan 71
Hi Steve,
If you want to preserve the surface under the material be careful what kind of tools and abrasives you use. For example, no metal tools.
If using liquid or gel paint stripper be certain it's safe for use on fiberglass and won't soften the surface.
I've had good results using kerosene and lacquer thinner.
Regards,
Alan
Old Feb 20, 2018 | 09:19 AM
Cavu2u's Avatar
Cavu2u
Got it Alan! THANKS.
And those pictures are great. I now know what the shape of the original structure is and what the repair should be.
Steve
Old Feb 20, 2018 | 12:34 PM
Cavu2u's Avatar
Cavu2u
1) Heat Gun
2) Scrapper
3) Paint stripper
4) Scrapper
5) Lots of rags
Great advice Mr. D.
MUCH APPRECIATED!
Steve
Old Feb 20, 2018 | 12:50 PM
derekderek's Avatar
derekderek
I would start with a power washer and see how much that gets right off the bat. Just don't use a zero degree tip. That could blow right through the fiberglass.
Old Feb 20, 2018 | 01:05 PM
Mr D.'s Avatar
Mr D.
Power Washer or commonly referred to as a Pressure Washer and Fiberglass do not play well together.
I would strongly recommend against this.
Old Feb 20, 2018 | 03:02 PM
derekderek's Avatar
derekderek
They have been doing boat hulls with them as long as there has been fiberglass and pressure washers. Gel coated exteriors and raw glass bilge both. Never seen a chip of resin flake off.
Old Feb 20, 2018 | 03:53 PM
Mr D.'s Avatar
Mr D.
I have owned several of both and a boat hull is a whole different animal than a Corvette body. Corvettes do not have Gel Coat.
Old Feb 20, 2018 | 03:56 PM
Cavu2u's Avatar
Cavu2u
Thanks men. I've got the idea. I'll take it slow, cuz being retired means takin it slow, for me anyway.
Just wondering how I'm going to fabricate a curvy 90 degree lip. That'll take a while.
Steve
Old Feb 21, 2018 | 01:12 PM
Cavu2u's Avatar
Cavu2u
Driver's side Fender Well has at least a bit of edge to get the repair started. Thinking of using material like metal screen door screen, or a plastic milk carton, to form the base, and then glass over it. Not going to look pretty, but will do my best to finish it off.
BTW, last picture has 3 mounting holes that I noticed in Alan's photo were holding something. What goes there, which is underneath the Windshield Washer Bottle in this '73 Coupe. Thanks much.
Steve
Old Feb 21, 2018 | 02:53 PM
Alan 71's Avatar
Alan 71
Hi Steve,
The 3 holes are for bolts for the bracket that mounts the vapor canister on the other side of that apron.
Regards,
Alan
Old Feb 21, 2018 | 04:55 PM
Cavu2u's Avatar
Cavu2u
Originally Posted by Alan 71
Hi Steve,
Regards,
Alan
ahhh...smog stuff.
Yeah, the previous owner stripped everything associated with environmental protection OFF & OUT!
Thanks Alan.
Steve
Old Feb 21, 2018 | 09:52 PM
lvmyvt76's Avatar
lvmyvt76
I too wanted the undercoating off the car, ssssoooooooooooooooooooo I got under the car and used simple green and a soft brush to work it off, then painted some areas and then recoated the fender wells to help protect them from road grime. A lot of time and work to clean an area that very few get to see, but the guys at the alignment shop got to see the under neath and they ooohhgh and ahhhhed at it.
To Another Undercoating Question.
