A/C low pressure switch
Old Feb 20, 2018 | 06:47 PM
Wrecked82's Avatar
Wrecked82
Default A/C low pressure switch
Noticed a few days ago that the wires at the low pressure switch for the a/c had two wires somewhat frayed such that the wires were exposed. While not touching, still close. What would be the results if the two exposed areas "connected".
Since, have isolated the two wires from each other and secured them to be separate by using silicone. Covered the silicone, once cured with Ultra Black Permatex gasket maker to make the solution less visible.
Old Feb 20, 2018 | 09:36 PM
JPinAZ's Avatar
JPinAZ
Compressor would never cycle. Evaporator could freeze up, compressor could be damaged.
Old Feb 21, 2018 | 11:24 AM
Wrecked82's Avatar
Wrecked82
Looks like I avoided a catastrophe then.
To A/C low pressure switch
