Ignition kill switch
Old Mar 3, 2018 | 04:22 PM
PeterC3's Avatar
PeterC3
Default Ignition kill switch
Anyone install a such a theft prevention device?
My mechanic suggested we install one while redoing the interior on my '81.
Old Mar 3, 2018 | 04:59 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
park it in a better area and forget about it. and you can never stop someone with a winch and trailer
Old Mar 3, 2018 | 07:54 PM
Mod75's Avatar
Mod75
2024 C3 of the Year Winner - Modified
Not so much a kill switch but works the same way.
Use the purple wire on the neutral safety switch, mount the switch any where you please.
Under the ashtray is works fine.
Old Mar 4, 2018 | 08:11 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I bought one from Summit. Its a big red plastic key and the switch kills power to the starter which kills all power to the car, It has 2 male connectors that are switched off the same key which allows you to maintain power to the radio memory and the clock. The key is removable when switched off. I mounted it between the seats so I can easily see it and remove it when I park at shows. I also wired it to a light on the dash so I know when I have power
Old Mar 4, 2018 | 08:29 AM
trukatedave's Avatar
trukatedave
When I first got my 79 someone had put a toggle switch inline with the primary distributor wire and mounted it near my left foot in a bracket near the kick panel. Took me awhile to figure that one out.
Old Mar 5, 2018 | 07:04 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
FWIW: your 81 has a factory theft prevention system with starter interrupt.
Old Mar 5, 2018 | 04:33 PM
oldgto's Avatar
oldgto
I installed a battery switch, (more to keep from draining the battery while it sits, than for theft). I put it in the battery compartment, with the switch handle in the glovebox.
To Ignition kill switch
