1980 electical issues
Old Mar 7, 2018 | 05:50 PM
bailey217604's Avatar
bailey217604
8th Gear
Default 1980 electical issues
Here is a stumper. For me anyway.
I have a 1980 coup, all of the sudden my heater fan and wipers will only work when my drivers door is open. That is when the door switch is open, they work. When you push it in they stop. Help????
Old Mar 7, 2018 | 06:59 PM
Cooter Tech's Avatar
Cooter Tech
Have you checked your ground cables by the starter, are they clean and tight? I think your wiper motor and blower motor share the same ground follow the black wire on wiper motor, it should go to the bell housing, fan motor too. Check the wires for corrosion and the connection. I think your door switch is providing a ground for your fan and wiper motor.
Old Mar 7, 2018 | 10:59 PM
bailey217604
8th Gear
Hey thanks Cooter. Yes I did trace that ground and found it broken. It's all a go now. You are a great asset as well as the others on here. Thanks for the wisdom.
Old Mar 7, 2018 | 11:34 PM
SciVette's Avatar
SciVette
This forum has taught me that any "odd" electrical issue requires a check of ground wiring before any further time and energy are spent...
Old Mar 8, 2018 | 05:17 AM
Cooter Tech
Glad you found it, grounds are strange animals and will cause you grief and money thinking parts are bad.
Old Mar 10, 2018 | 11:48 PM
81vettski's Avatar
81vettski
impressive diagnosis Cooter!
To 1980 electical issues
