Question on Removable Rear Window Lower Trim
Old Mar 8, 2018 | 08:59 AM
68/BB's Avatar
68/BB
Default Question on Removable Rear Window Lower Trim
I have been trying to put this piece in my '68 Coupe and it will not fit correctly. It is aftermarket and the problem may be related to that or because I have the wrong piece. I cant get the "Velcro" pads to engage. I have an original to compare it to and there are some differences between them, but not a lot. The original is shorter, however, after using aftermarket quarter panel pieces it appears that it needs to be longer. If I were to use the original it would not fill the gap between them. The original did not have screws. It had two pegs in the top to hook in openings in the body and the Velcro pads. However, there are two spots in the body with little clips to put the screws into. But the spacing just doesn't match up to the holes in the trim. Close but not quite. So right now I cant make the Velcro grab and I cant make the screws fit. Is it possible that there are different versions of this trim piece for different years and I have the wrong one?
Old Mar 8, 2018 | 09:23 AM
Alan 71's Avatar
Alan 71
Hi 68,
I would expect 68 cars to have the piece of lower trim mounted without screws.... but?
Here's a photo of the quarter panel trim and the u-nut slipped on that little fiberglass bracket.
Does this help with the position of the screws when they began being used?
Regards,
Alan
And one with the quarter trim removed. Notice on this one the screw was driven into the fiberglass, not the u-nut, when the car was assembled.
Old Mar 8, 2018 | 09:29 AM
68/BB's Avatar
68/BB
Originally Posted by Alan 71
Hi 68,
Regards,
Alan
That is very similar to what my '68 looks like. It has the same clips. I wonder if the original quarter panel trim had screws that went in there and the lower trim just snapped on over them. The aftermarket has holes in the lower trim that like I say almost line up with those clips but not quite. I would leave them out if I could get the Velcro to engage, but it wont.
Old Mar 8, 2018 | 09:46 AM
Alan 71's Avatar
Alan 71
Hi,
How much are the screw holes in the trim 'off' by?
And in what direction... too narrow, too wide"
Regards,
Alan
Old Mar 8, 2018 | 11:06 AM
68/BB's Avatar
68/BB
Hi,
Regards,
Alan
They are too narrow in the trim by about 3/16" I would guess.
Old Mar 8, 2018 | 03:21 PM
68/BB's Avatar
68/BB
I gave up struggling with the aftermarket piece and was very fortunate to find an OEM one locally in excellent condition. Amazing how when they are made correctly they actually fit.
Old Mar 8, 2018 | 03:52 PM
Alan 71's Avatar
Alan 71
Hi 68,
That seems to be especially true with reproduction interior parts!
I'm glad you were able to worked this out!
Regards,
Alan
Old Mar 8, 2018 | 04:11 PM
68/BB's Avatar
68/BB
Yes, I dry fitted it and it looks good. I just shot it with gunmetal color and when it dries I will proceed. I am very glad that we have aftermarket for the times when you don't have another good option. However, like you say, it seems like interior trim is almost always a struggle. This time, thanks to a local Vette shop that is ran by a super nice guy, I got hooked up with a quality OEM piece for less money and a nice fit. Win, win. As they say. :-) Next is to move on to the overhead area and still keep tweaking that window until I get it nailed down right. I will be SO glad to finish this rear area and move on towards the front, seats, door panels, etc.
Old Mar 8, 2018 | 04:27 PM
69ttop502's Avatar
69ttop502
I ran into the same trouble with a repop one on my 69. Going to try to repair my original. Been looking for an original with the two studs still intact but haven’t found one. You were lucky to find one.
Bill
Old Mar 8, 2018 | 04:37 PM
Alan 71's Avatar
Alan 71
Hi Bill,
What are the 'studs' like?
Do they have tiny rings on them like the 'studs' on the overhead center piece?
Regards,
Alan
Old Mar 8, 2018 | 05:51 PM
68/BB's Avatar
68/BB
Here is my old one showing studs or pins on back side. Also, you can see the new one recently painted and one of the overhead (halo?) sections which is my original piece just painted to freshen it up. The replacement piece I found is not '68 "correct" because it uses screws in addition to the Velcro. However, in my case I needed the screws to hold the quarter trim in position.
Old Mar 8, 2018 | 06:10 PM
68/BB's Avatar
68/BB
Bill
are the studs broken on your original?
Old Mar 8, 2018 | 07:38 PM
loup68's Avatar
loup68
Army
It is unbelievable how every part on a 68 is different than a 69! I love the 68 coupe interior sail panel courtesy lights. Lou.
Old Mar 8, 2018 | 09:37 PM
68/BB's Avatar
68/BB
I agree. I think having the lights in there was a really cool place to put them.
Old Mar 10, 2018 | 07:55 PM
loup68's Avatar
loup68
Army
I did add the 69-up light on the back wall to light up the storage area on mine. The bracket is present on our coupes, even though there was no light back there. Lou.
Old Mar 12, 2018 | 11:20 AM
68/BB's Avatar
68/BB
Hi Bill,
Regards,
Alan
Question for you Allan on that stud. Is that just a locating pin or does that fit thru the center section and have a nut and washer used on it? I cant tell by looking at the AIM if a nut goes on that or not and I am getting ready to install that center trim piece.
Old Mar 12, 2018 | 01:14 PM
Alan 71's Avatar
Alan 71
Hi 68,
It holds the trim piece in place.
The 'ringed' stud in the piece of trim mounts in a flat spring steel plate that's pop riveted to the birdcage. The plate has a small diameter hole in it.
You install the trim piece by giving the trim a 'pop' with the side of your hand. This pushes the stud through the plate and the plate grabs the rings.
To remove the piece you give it a gentle 'jerk' to get the stud to release out of the hole in the plate.
Obviously this method was designed while thinking this piece of trim might never be removed in the life of the car.... but we screwed that theory up.
Regards,
Alan
Old Mar 12, 2018 | 02:31 PM
68/BB's Avatar
68/BB
Hi 68,
Regards,
Alan
Ok, that's good to hear. So it has rings and not threads. I didn't look at it close enough. I was afraid I would have to remove that chrome top cover on center section and I didn't really want to disturb that area after sealing it. Thanks
To Question on Removable Rear Window Lower Trim
