Wiper door fit
fitting wiper door... best fit I've managed to achieve so far is below.
Given that I've no real comparators - I've got no idea if this is a reasonable fit or not!
is it usual for the wiper door trim to sit proud of the panel trim? and for the wiper door curve to sit proud of the grille in the centre?
if the answer to either of the above is 'no' - any suggestions to improve?
(and yes - i know i scratched the trim.. i'll fix it when i've got it finished!)
many thanks for your thoughts!
The wiper grill was often shimmed up in it's center to help it's 'arc' match the 'arcs' of the wiper door and and the hood.
The gaps between the hood, grill, and wiper door appear wider than what would have been typical when the car left St.Louis.
These gaps are really a function of the length of the hood, it's gap at the front, and the position of the wiper door relative to the windshield.
In looking at the photo it appears from the position of the screws in the grill slots that the grill is 'forward' causing the wide gap between the grill and door.
Obviously moving the grill back will help the gap between the grill and door, but increase the gap between the grill and hood.
Can the hood come back at all?
What's the gap like at the front of the hood?
What is the hood you're using?
Regards,
Alan
Offered for comparison.
I did not know about the shimming. I'll have to try that when I put mine back together.
