Rear bumper
Old Mar 27, 2018 | 08:35 PM
Justin97's Avatar
Justin97
8th Gear
Default Rear bumper
Hello,
I have a 1975 stingray and the rear bumper has some cracks in it. Before I replace the whole bumper, I’d like to epoxy the cracks together for now. What would be the best to use on this plastic? Thanks!
Old Mar 28, 2018 | 11:45 AM
MelWff's Avatar
MelWff
how about this
https://www.walmart.com/ip/Bondo-Bum...&wl13=&veh=sem
Old Mar 28, 2018 | 11:50 AM
Justin97's Avatar
Justin97
8th Gear
Originally Posted by MelWff
Thanks! I’ll look into that. What about something clear for now?
Old Mar 28, 2018 | 11:54 AM
KenSny's Avatar
KenSny
IF it is the original it is made out of urethane, not plastic.
Epoxy will not stop the cracks from getting bigger.
My original bumper would crack at the slightest bump - it was getting brittle, eventually a piece actually came loose and fell out.
My advice, don't waste your time, and money, using epoxy to stop this. Replace the bumper cover.
Old Mar 28, 2018 | 11:56 AM
Justin97's Avatar
Justin97
8th Gear
Thank you! It is the original bumper. I will replace it, just looking for a way to help the issue until then. Appreciate your time!
Old Mar 28, 2018 | 12:04 PM
~Stingray's Avatar
~Stingray
St. Jude Donor '17, '19
Well if you are just looking to get by, superglue the cracks and ducktape over on the inside of the bumper. Not visible and should hold it together. Won't prevent the crack from getting bigger but can help prevent things from getting bigger from a lack of support or over-strain.
I only recommend this if you are gong to replace the bummer. But this help the NEED to replace it a little longer buy holding it all together.
Old Mar 28, 2018 | 12:07 PM
Justin97's Avatar
Justin97
8th Gear
Appreciate it! Thank you!
Old Mar 28, 2018 | 03:13 PM
derekderek's Avatar
derekderek
These orig bumpres will keep cracking till they fall apart and right off the car. Yours must have always been stored inside, or it would have been long gone by now. Don't get your Hope's up for it lasting much longer. 76 or 77 they changed the urethane compound and bumpers lasted longer. The 80 style with little spoiler built in is somewhat better looking IMO.
Old Mar 28, 2018 | 03:20 PM
Justin97's Avatar
Justin97
8th Gear
Yes they are the oringinal and it has always been stored inside. Good to know! Appreciate your time!
To Rear bumper
