Engine Block Questions
It sat outside for a lot of years prior to finding its way to my home.
When I drained the oil I got about two quarts of oil out and about five gallons of water from the block. I didn't know water was a good block lubricant but hey, I learn something new every day.
I would like to take it apart and see if there is anything that can be salvaged from the block or its internals. I plan to throw the intake and the heads back to recycle the metal but would like to get in there and check it out.
Now I have taken apart four or five engines previously and have always scraped my knuckles getting the intake manifold off, nothing new there.
But this one is stubborn. I got all but the center four bolts off of the intake and there just isn't enough clearance to get the inside four off.
I have tried all the methods my friends have recommended including a really nice set of biting bolt head removal sockets.
I haven't tried heat yet.
I even thought about removing all the bolts from the heads and seeing if the heads and intake could be removed together.
Anyone else figured this one out and solved it?
I'm all ears.
Thanks in advance for any guidance you may provide to me and anyone else that might be following along.
David
Not sure that answers my question really but maybe I wasn't clear in what I wanted to accomplish or maybe you didn't understand the question. In either case I would have already given it away if I wanted to take the lazy way out.
Anyone else?
David
Tips, tricks, or methods that work is what I am seeking here folks. Not looking for why I shouldn't bother with this block.
Thank you.
David
One of the mechanics that used to work with us would always seem to have an answer for a question like this !
Every week he would be on the tool trucks that came on property and would buy something from each one !
I'll ask on Monday and see if I get any suggestions!
Steven
Steven
Thank you.
David
David
I would use a 4 or 6 inch angle grinder and just cut the bolt heads and be done, or the hot knife as a second option.
I'm all ears.
David
I like your new avatar. cool pic!!!
