tach drive cable clip question
ok so I want to change out my tach drive cable and I can get my fingers up to the back of the tach but cant figure out which way the clip needs to be activated to release the cable. If your laying on the floor and you have your hand up on the back of the tach, on the cable were it connects what way do you activate the clip to release. would it be a push towards the tachometer or pull out towards the firewall or what?
Lyndwood (04-01-2018)
ok a couple months old but i removed my old cable with no issues, accept a tight fit fro my hand. I got the new cable on the tach post but it does not seem to be on all the way. I tried pushing it on further but it doesn't go anymore, should the retaining wire (the one you push to remove the cable) be on the new cable or around it to capture it or does it stay in front of the cable end (between the cable end and rear of the tach. i was expecting to here a "clip" or feel one when I slid the new cable on the post. am I doing something wrong?
ok, 3 minutes later and i solved my own problem, I had to spin the inner drive on the exposed end to get the one end to drop it into the socket on the tach then the outer cable end snapped into the retaining wire.
