power antenna on a 1978 corvette
Old Apr 7, 2018 | 12:51 PM
Danny55's Avatar
Danny55
3rd Gear
Default power antenna on a 1978 corvette
when the radio is powered up I can here the motor running to send the mast up but mast does not go up! can just replace the mast without buying the whole power antenna assembly?
Old Apr 7, 2018 | 01:09 PM
av81's Avatar
av81
yes , if you take the top nut off you can pul out the mast.
Old Apr 7, 2018 | 01:15 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Well, that's making it sound easy!
After you remove the "top nut"(finial) you pretty much need to disassemble the entire antenna to do the repair.
The nylon cable inside that pushes the mast up and down is broke and the broken cable will be wound up inside the motor.
Check out this thread for repair process.............
https://www.corvetteforum.com/forums...e-antenna.html
Old Apr 7, 2018 | 01:30 PM
av81's Avatar
av81
I got my whole interior out right now (stress city) anything to do with an antenna sounds easy for me right now I would say just replace the antenna rather than taking apart a 30+ year old part , I do not recommend the Ecklers antenna I just bought one all it is is a universal antenna with a dozen parts you have to go through and figure out ... I would say look for a better replacement , I think the one I got cost $114 something like that.
Old Apr 7, 2018 | 01:42 PM
KapsSA's Avatar
KapsSA
The 78-EARLY79 antenna is a completely different unit than Late79-82. Used for only that 1 1/2 year period.
Same type of function and basically same repair.
I like to keep things original, and assume unless told otherwise that the Vette in question is hopefully low mile.
I agree the "correct replacement" antennas sold by the vendors is an inferior product.
Old Apr 7, 2018 | 02:51 PM
Danny55's Avatar
Danny55
3rd Gear
Thanks!
Old Apr 8, 2018 | 10:35 AM
Danny55's Avatar
Danny55
3rd Gear
Thanks!
To power antenna on a 1978 corvette
