C3 Suddenly died while driving
Old Apr 11, 2018 | 01:00 PM
El Jefe007's Avatar
El Jefe007
8th Gear
Default C3 Suddenly died while driving
I have a 1981 C3 corvette that is a partial project car. I was driving it on the freeway when all of a sudden everything just stopped working. Choke and battery light came on but the car was not running. The interior electrical was all still on and fine. I pulled over and all the belts were fine. This happened once before and I had to replace the distributor. Any ideas on why it died? I have a new alternator, new distributor with all new plug wires. I just got through replacing the smog pump and the radiator.
Old Apr 11, 2018 | 01:22 PM
The Punisher's Avatar
The Punisher
does the engine turn over?
Old Apr 11, 2018 | 01:24 PM
El Jefe007's Avatar
El Jefe007
8th Gear
Turns over but won't start.
Old Apr 11, 2018 | 01:33 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
check power to dist. should say "batt" on the cap/
first thought ign cont mod
coil
mag pickup
if you are getting 12v to dist.
unplug 4 lead connector at dist and try to start
how familiar are you with dist and hei?
JasonAndrew's Avatar
JasonAndrew
HEI distriburor? , points? Hei distributors gave a module that goes out, leaving no ignition. Getting fuel to carb.?
Old Apr 11, 2018 | 01:45 PM
El Jefe007's Avatar
El Jefe007
8th Gear
Calwldlife Not familiar with them at all, but not afraid to dig in. This is my first project car and its been 30+ years since I've messed with points, plugs, rotators and distributor caps.
J
Old Apr 11, 2018 | 01:46 PM
El Jefe007's Avatar
El Jefe007
8th Gear
Yes, you can smell the gas when you pull off the air cover.
Old Apr 11, 2018 | 02:03 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
J
no points in hei
a device called magnetic pickup. coils of wire in a ring shape
bottom of dist serves as points by signaling the ignition control module.
research ign cont mod to get an idea of what it looks like.
remove it and take to autozone for testing.
Old Apr 11, 2018 | 02:29 PM
carriljc's Avatar
carriljc
Do you have spark? If not, then I'd check ignition module first if I was you.
Ignition modules go from about 25 to 75 bucks at autozone. Only mention autozone because it's nearest parts place to me.
https://www.autozone.com/ignition-tu...eVehicle=false
Originally Posted by calwldlife
no points in hei
Old Apr 11, 2018 | 02:36 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
new dist could have spun and put the car out of timing.
depends on how tight the hold down was and
if the shaft bound up on the dist housing.
i would verify 12 v to dist cap
that rotor turns
that dist hasn't spun by looking at the position.
then test ign module
coil
mag pickup.
the sudden stopping vs rough running sounds like electrical
Old Apr 11, 2018 | 02:45 PM
carriljc's Avatar
carriljc
Get a timing light and see if you have spark. See if your timing seems about right. Do you have a spare coil? (may be silly, but I seem to have had a spare around my whole life).
Old Apr 11, 2018 | 03:10 PM
El Jefe007's Avatar
El Jefe007
8th Gear
OK sounds like everyone agrees that it is most likely the distributor or the control module. The distributor was replaced a couple of years ago and has less than 2000 miles on it but I don't think the control module has ever been touched so I'll start there.
Thanks for all the help guys, I truly appreciate it.
Old Apr 11, 2018 | 10:25 PM
Vettedreamer74's Avatar
Vettedreamer74
Happened to me last year where power wire literally fell out of connection and car died in the middle of town. Thankfully I coasted to a bar parking lot and figured out the connection much later.
Old Apr 16, 2018 | 10:13 AM
El Jefe007's Avatar
El Jefe007
8th Gear
Thanks for all the help. I opened up the distributor this weekend and found the problem. What I thought was a new distributor was just a new cap and plug wires. The guts were all old and the rotator arm had broken. $40 for a new arm and new cap and we are back up and running.
To C3 Suddenly died while driving
