'72 Vette
Apr 20, 2018 | 03:09 PM
4th Gear
'72 Vette
My temperature control gauge is not working, could it be fuse related?
Apr 20, 2018 | 03:35 PM
Hi Gene,
Welcome!
You can check the fuse for the gauges.
It's on the lower right of the fuse panel.
You might also check the electrical connector at the temperature sender in the left side head.
Regards,
Alan
The wire lead has a woven protective 'sheath' on it.
Apr 20, 2018 | 04:41 PM
4th Gear
72 Vette
Quote:
Originally Posted by
Alan 71
Hi Gene,
Welcome!
Regards,
Alan
All my other gauges work so that fuse is ok. I'll check electrical connector at the temperature sender as you suggested.
Thanks again.
