Hello,
Anybody know the outside bypass hose diameter so I can use the right clamps?
All the Wittek clamps are numerically stamped but not by diameter size. I imagine if I had their catalog the numbers would correspond to a clamps size in the catalog?
Looking to use two Wittek clamps for orig style look.
TIA,
Marshal
Hi Marshal,
The 5th Edition of the NCRS 68-69 Technical Information Manual & Judging Guide indicates that the water-pump bypass hose on 427 engines used 2 Wittek type 'D' single screw clamps, numbered 10.
Service replacements may be numbered 37 or 39.
Regards,
Alan
